Steal Seal or Blue Devil for Head Gasket
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by thechuckster, Feb 18, 2020.
  1. thechuckster
    thechuckster Junior Member
    17
    Has anyone ever tried Steal Seal or Blue Devil sealant on a Gen 3 Prius? I have a 2010 Gen 3 with over 275k on it and "milky" oil. I get white smoke out of the exhaust for about 1-2 minutes then it disappears. Rough start (engine shaking) at first then it seams to immediately disappear. Does not happen with every start, engine shaking is random. Mechanic confirmed misfires in cylinders and a bad head gasket.
    I LOVE MY PRIUS... But it is almost time for us to part ways.. :(
    Wanted to see if anyone has had success with any head gasket sealants. Looking to get another 10k miles out of the car before I sell it.
    Thanks in advance for your help!
    thechuckster
  2. ChapmanF
    15,111
    There are a bunch of threads on here where somebody has tried that stuff. Nightmares for the next owner. If it is almost time to part ways, I think you'll do the next buyer a favor if you just tell them the gasket is going, and sell them the car un-gunked, so they have can have a decent shot at fixing it.
  3. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    That’ll lead to less potential buyers and lower list price.
    thechuckster and Mendel Leisk like this.
  4. ChapmanF
    15,111
    And clearer conscience, if that's even a thing anymore.
  5. Leadfoot J. McCoalroller
    6,845
    6,488
    Pennsylvania
    2018 Prius c
    I'm against the use of that stuff, with an exception for emergency evacuation. If using it is going to let you escape certain doom, then use it and dump the car afterwards.
    If you want to be nice to the car, avoid headgasket-in-a-bottle and accept that it is already time for major reinvestment. Overhaul of this vehicle is needed now if you want another 10k miles, and maybe that means it's just time to move on to another car.
    thechuckster likes this.
  6. Rebound
    Rebound Senior Member
    3,961
    2,609
    Portland, OR
    Once you pour that stuff into an engine, you cannot repair the engine by simply replacing the head gasket. The engine needs a complete rebuild or replacement, along with the radiator and all the cooling hoses.
  7. Mendel Leisk
    38,260
    I'm pretty sure @Grit was being sarcastic, or ironic. Sad thing is: it's true. Didn't unscrupulous sells put sawdust or something in tranny's, back in the day?
    Apparently, with at least on such product, running a 50/50 mix of water (preferably distilled) and white vinegar, will miraculously dissolve the goop. Someone here has tested this, with blobs he managed to scoop out, and it worked, fast.
    @thechuckster , if you're anywhere near San Fransisco, maybe just call Gasket Master. They come to you, do head gasket replacement, under a grand if I'm not mistaken.
  8. thechuckster
    17
    Appreciate the response and I understand your point. When I sell it (probably very soon), I will let the buyer know about the head gasket situation. Un-gunked is definitely better than "gunked".
  9. thechuckster
    17
    A clearer conscience is always a thing in my book. Will be 100% honest when I sell the car, just wanted to get a few more months out of it before selling it.
  10. thechuckster
    17
    I was planning on trying a bottle (with water, thermostat removed, and fresh oil), letting it cure overnight, flush the system again, install the thermostat and a second oil change. I wanted to get as much sealant out of the system that did "bind" to the leaks.
    Doing all of the work DIY.
  11. thechuckster
    17
    @Mendel Leisk thanks for the water / white vinegar suggestion. If I do give the "snake oil in a bottle sealant" a try, I may use the vinegar on the second flush. Below was my DIY plan of based on my research.
    A bottle of sealant (with water, thermostat removed, and fresh oil), letting it cure overnight, flush the system again, install the thermostat and a second oil change. I wanted to get as much sealant out of the system that did not "bind" to the leaks.
  12. Mendel Leisk
    38,260
    That may dissolve all of it, not sure.
    I would go straight to head gasket repair myself.
  13. thechuckster
    17
    @Mendel Leisk BTW, I wish I was in San Fransisco.... Gasket Master would have my business for that price. Unfortunately, it is hard to find someone in north PA that will work on a Prius. I talked to a lot of mechanics, few want to touch it and others want to charge $2500 to change the head gasket.
  14. thechuckster
    17
    Good point, I was thinking about how the vinegar would act on the cured sodium silicate (the active ingredient in most head gasket sealers).
  15. Rebound
    3,961
    2,609
    Portland, OR
    It’s the same internal combustion engine used in other Toyota’s. The hybrid feature has nothing to do with it.
  16. Mendel Leisk
    38,260
    Gasket Masters are cut-throat and corner cutting. The $2500 quotes might entail more, procurement and install of the complete Toyota gasket overhaul kit, sending the head out for cleaning, check over and install of fresh valve seals (part of the kit). In other words, there are different levels. But if you're considering short term, yeah someone like Gasket Master is maybe the way to go.
  17. GearHead600
    GearHead600 Member
    64
    74
    Chicago, IL
    I honestly would never use that stuff (just like i'd never use "fix a flat"), all that gimmick "stop leak" crap is just that, crap! Even if you're looking to part with it sooner than later I still don't see it being of any real value or help to you. May as well put the price of whatever the bottle(s) are toward an actual repair, or the next subsequent replacement vehicle! The only real options in my mind are, literally just rock it until it doesn't "go" any more without putting ANYTHING more into it (besides gas). Once it does "die", get a replacement vehicle. Or you fix it "the right way" right off the bat! I see two ways that could be possible once you've experienced "milkshake"... Option 1) Have the head gasket done, fully, properly (including checking rods and rod bearings / entire lower end of motor - etc). Or Option 2) Drop in a replacement motor - which of course branches into two more sub-options of either 2A) you go with an OEM / brand new motor (very expensive I'm sure on parts and labor), or 2B) have a bone-yard motor tossed in (much cheaper than new ofc)...
    TLDR; Honestly it's a waste, I don't care if it's only $10 for the bottle - that's $10 you could've spend on gas or toward an actual repair, or toward a replacement vehicle!
  18. thechuckster
    17
    I leaning to getting the head gasket fix right if it can yield me a year or two of service. Wish I could find a shop that will do it for under $1000, but I'm probably dreaming.
    Everyone one I talk to says that it is a 50/50... 50% say it will probably seal the leak, the other 50% say it may do more harm than good.
    A small percentage say, give it a shot... But be warned, it can really gunk up your engine!
  19. GearHead600
    GearHead600 Member
    64
    74
    Chicago, IL
    It can mess up a whole lot in terms of "gunkin" it up. It can not only "gunk up" the engine (and all the coolant ports where coolant is supposed to flow), which is bad enough in and of itself (gotta keep the motor cool after all)! I've heard it can wreak havok on your thermostat, water pump, heater core. Basically, it WILL "muck up" anything any everything the coolant flows through. So IMHO it's really not worth the "risk" even if it "does its job" of "sealing the head gasket", because even if you (it) miraculously sealed the gasket leak, you've now created TEN (10) more problems. Like the thermostat, water pump, heater core, etc!
    Just my $0.02
