New Head Gasket!
Discussion in 'Gen 3 Prius Technical Discussion' started by RyanFlorida, Apr 30, 2018.
  1. ASRDogman
    ASRDogman Senior Member
    5,909
    3,167
    That's great! I hope you get at least another 172,000 on it!
  2. douglasjre
    douglasjre Senior Member
    1,774
    617
    Orlando, FL
    Your hg want at 130k? I'm in Lakeland. What part of FL?
  3. tri4all
    tri4all Member
    98
    52
    Pacific Northwest
    does anyone has the torque specs for the top engine cover? I could not find them in the manual
  4. Mendel Leisk
    38,260
    Very minor, 7 foot/pounds.
    tri4all likes this.
  5. Igortigor
    Igortigor Junior Member
    Portland
    Hello
    anyone here is willing to share complete repair manual for this job? Thanks.
  6. douglasjre
    1,774
    617
    Orlando, FL
    I used the search function and YouTube
    Igortigor likes this.
  7. Ed Beaty
    Ed Beaty Active Member
    334
    309
    Salt Lake City
    Pretty sure there's no 'complete repair manual' resident on this forum. You just have to look around and try to piece things together.
    Searching on YouTube can be very fruitful, altho you're also likely to get poorly produced vids or ignorant vids. YMMV.
    One way I've found to get productive searches done is to Google (not PriusChat search) something like: '2010 Prius replace head gasket', or '2010 Prius head gasket' (I have a 2010 Prius; you might substitute '2012 Prius'). What you'll get is nice bunches of related threads on PriusChat in your Google result, and you can look through those. Along the way, you should find a link to a video of two experienced guys replacing a 2010 Prius head gasket (it's on YouTube, of course). They move along at a blistering pace, but they know what they are doing.
    PriusChat search might also be useful, but I really liked the above method.
    I got LOTS of Prius info, of all sorts, not just head gasket related, using it.
    EDIT: BTW, the title of that HG video: Toyota Prius 2ZR head gasket replacement (complete step by step). Be sure to look at the video description for info on tools required for the job.
    #47 Ed Beaty, Mar 27, 2020
  8. Cosmo Tigato
    Cosmo Tigato Active Member
    183
    359
    Oregon, USA
  9. prius_deep
    prius_deep Member
    105
    road
  10. Mendel Leisk
    38,260
    I'm not sure I buy their explanation, think the EGR clogging plays a big part. I've commented on this, on their YouTube location. See they've responded, and I've just replied.
    I like their videos, think they're invaluable, but their explanations are maybe too pat.
    #50 Mendel Leisk, Mar 28, 2020
    Cosmo Tigato likes this.
  11. Igortigor
    Portland
    Thanks. Just finished job, put everything back together, started car in maintenance mode. It runs rough and stalls with code P3190. Which has to do something with fuel.
  12. Cosmo Tigato
    183
    359
    Oregon, USA
    Dirty Injectors?
    #52 Cosmo Tigato, Mar 28, 2020
  13. Mendel Leisk
    38,260
    What was it you did exactly?
  14. Igortigor
    Portland
    I did head gasket change. Injectors were really gunky. I used break cleaner to clean them. I also cleaned intake manifold and throttle body at the same time. I guess next thing I’ll try is cleaning fuel system. Car hasn’t been started for at least 3 month until today after I finished HG change.
  15. Mendel Leisk
    38,260
    Maybe an intake manifold gasket leaking? Did you change all IM gaskets? If not, doing so is maybe $50 and relatively easy.
  16. Igortigor
    Portland
    I bought gasket kit from Toyota that someone recommended here on priuschat for this job. I didn’t use all of them, but I did replace intake manifold for sure.
  17. douglasjre
    1,774
    617
    Orlando, FL
    What kind of head bolts stretch more?
  18. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    276
    Redwood City, California
    If you are referring to the issue discussed in the video above ...
    Titanium bolts would have about half the stiffness (modulus of elasticity, Young's modulus, etc.) as the same sized steel bolts, with similar strength. Titanium has other issues being screwed into an aluminum block. But I believe in some applications, such as race motorcycle engines where engine teardown may be a common thing, they are sometimes used. Higher maintenance.
    If you stick with steel, the stiffness does not vary much, even across different alloys and heat treating.
    So what they (engine designers) typically do to make the head bolts more compliant is simple - they use thinner bolts. Obviously those will stretch more. An M10 bolt is thinner than an M12, with about 44/144 less surface area and proportionally less stiffness.
    To get the strength they still need, with that extra compliance, they use very strong bolts to begin with - e.g., Class 12.9. And then they are plastically deformed when installing = torque to yield, TTY. The work hardening that occurs during the TTY process makes them even stronger. It has to be done carefully, but when it is, you have strong bolts that are also compliant. So that's the main reason why high grade / class, TTY, steel bolts are typically used for head bolts. The TTY process also leads to more uniform clamping force across the head, which is another reason.
    And if that's not what you were asking, hopefully it's helpful to someone else.
    #58 2012 Prius v wagon 3, Mar 29, 2020
    Ed Beaty and Robert Holt like this.
  19. Mpdcnva
    Mpdcnva Member
    27
    Washington dc
    Four Touring
    Can someone tell me the purpose of disconnecting the battery; batteries? In the old days, cars had an alternator and starter, which had live wires going to each. A Prius doesn’t have that. I did the head gasket and did not disconnect either battery. It was funny to hear the solar running the hvac fan, however, all the work I did had no affect on anything. After thoroughly cleaning the tops of the cylinders and reseating the valves. I went from 50 to 55 mpg at 192000 miles.
    douglasjre likes this.
  20. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    Soyou can do electrical work related on the car or clear memory stuff, and not get a electrocuted by the high voltage.
    Soh likes this.
