Low Beam works and doesn't work
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Feb 23, 2020.
  1. Taxi/Limo
    Taxi/Limo Active Member
    509
    107
    My drivers side low beam was not working then all of the sudden it started working again
    Now it is not working again
    Is this what a bulb on it's way out does or is it a connection problem?
    Thanks
    48,995
    sounds like a loose connexxion or corrosion
    Taxi/Limo and Mendel Leisk like this.
  3. Tim Jones
    Tim Jones Senior Member
    1,687
    547
    SE Texas
    2011 Nissan LEAF
    Has it been converted to LED?
  4. Taxi/Limo
    509
    107
    No
  5. Tim Jones
    1,687
    547
    SE Texas
    2011 Nissan LEAF
    Mine did the same thing but it was a LED failing. I put the stock lights back in.... very easy to change.
