Windshield wiper control arm illumination
Discussion in 'Gen 4 Prius Technical Discussion' started by moonchild36, Feb 23, 2020.
  1. moonchild36
    moonchild36 Junior Member
    2018 Prius
    Are the markings on the windshield wiper control arm designed to be illuminated at night? The control arm in my Gen 4 2018 Prius is unlit regardless of interior/exterior light switch settings. Thanks in advance.
  2. booke02
    booke02 Active Member
    391
    415
    Israel
    Not on my 2016 Gen 4
  3. bisco
    52,252
    it's not right, how do they expect you to find unlit controls
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I don't think so, but there is ambient light sufficient. Problem is trying to understand the codes on the switch. I almost never touch the arm - push away for rear-wiper wash, pull toward for front washer - otherwise, just leave it in AUTO.
  5. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    Maybe this video will help you to understand better...
  6. alanclarkeau
    7,045
    7,593
    That must be an old version - this is the Gen 4 version:
  7. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    You young guys have it so easy, this lit up that lit up etc.
    When I started driving, the only thing lit up at night was the speedometer and (if you had one) the radio.
    Gears were all manual (stick shift) and you had to fumble around in the dark to find the gear stick each time you changed, the handbrake (emergency or parking brake), all the switches and the heater (again, if you had one) controls.
    :rolleyes:
    alanclarkeau and krmcg like this.
  8. alanclarkeau
    7,045
    7,593
    True. High Beam was a button on the floor!!! Wipers were one of 2 or 3 knobs on the dashboard - pull of ON, push for OFF. No lights for the Window Winders either.
    kithmo, krmcg and WilDavis like this.
  9. Hidyho
    Hidyho Senior Member
    2,699
    531
    2018 Prius
    You should be able to get motorized windows now that Holden is gone...LOL. j/K
    kithmo, krmcg and alanclarkeau like this.
