Toyota USA Refuses to Honor Extension of Warranty Coverage for Sticking EGR
Discussion in 'Gen 3 Prius Main Forum' started by jburg, Jan 27, 2020.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    Welcome to 21st century technology(y).
  2. Mendel Leisk
    38,243
    We picked up a 2-pack of steel drinking straw cleaning brushes. One I'm using now for cleaning EGR passages on intake manifold. Work good with a shot of brake cleaner.
  3. Mendel Leisk
    38,243
    20th century tech still has it's uses. Nuts, bolts, plates, angles. 3D printing may allow you to make most any shape, but the materials are flimsy? I would still consider what's available in a hardware store, see if you can adapt it to your needs.
    Raytheeagle likes this.
  4. jburg
    jburg Member
    93
    RTP, NC
    Update: Start-up this morning didn't have any rattle and wife said the car is running well.
    Also, I have just come to the realization that my extremely detailed maintenance notes and records are not reflected on the Carfax data on any of my cars. What a waste of time... I was doing this so that if and when I had to go a shop, they wouldn't try and sell me or my wife on all the preventative maintenance that I have already executed. Kind of PO'ed right now...
    pjksr02 and Mendel Leisk like this.
  5. Mendel Leisk
    38,243
    The "cloud"...:rolleyes:
  6. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    Ive sold transferred cars that took me into wrecks and reported the wrecks to dmv, no none of my previous cars didn’t show any accidents even after year later on carfax.
  7. jburg
    jburg Member
    93
    RTP, NC
    Carfax called me. The only way that an individual can update their service records is to buy a subscription to a SMS (service management system) and then link the said system to Carfax by calling them up to verify their information. Carfax should reflect DMV/title reports, but not always. What I am saying is that I would rather buy a car from someone who has a handwritten notebook and receipts then completely trusting the Carfax maintenance record. Also, this is the reason why small mom and pop shops don't always show up on Carfax reports even if the car was maintained to the nines.
    Also, I am going to have to take the intake manifold and clean her again. My wife said the car shuttered a bit (but not as bad as it used to) in heavy traffic and low load on the way home from work. It seems like I didn't get the EGR ports good enough.
    Merkey likes this.
  8. Mendel Leisk
    38,243
    Just to recap:
    1. How many miles on the car now?
    2. There's new EGR cooler and valve in now, and connector pipe presumably clean?
    3. Intake Manifold has been cleaned, but you're not sure EGR passages are well cleaned.?
    4. Intake Ports (on the engine, beyond the intake manifold) wiped out as well?
  9. jburg
    jburg Member
    93
    RTP, NC
    1) The car has 1570079 as of today
    2) EGR cooler and valve are brand new. The EGR pipe was spotless when reinstalled.
    3) I followed the NutzaboutBotlz intake manifold video and he doesn't really go into detail about the EGR channels. 100% sure that I focused on the intake manifold itself. I honestly didn't realize that each cylinder on the head had an individual port that feeds recirculated/metered exhaust gas into the intake manifold. My guess is there is resistance in the system and that why it's studdering/chattering under low load. Funny thing is that the EGR was so clogged I don't think exhaust gas has been circulated since at least the first week of January when I first got the P0401 code and that's why that symptom has not resurfaced until freeing up the rest of the system.
    #29 jburg, Feb 24, 2020
  10. Mendel Leisk
    38,243
    I haven't got a clear pic, but they're right about at the red circles:
    If you do use oxi-clean, be sure to rinse VERY thoroughly, especially where bolts/studs will be installed. Maybe blow out with compressed air too. Or just stick with brake cleaner, that's good enough.
  11. jburg
    jburg Member
    93
    RTP, NC
    That is exactly what I am talking about. I was going to use the straw cleaners, 12 gauge shotgun brush, brake cleaner, and compressed air.
    Completely overlooked, feel like an idiot, but it's a good learning experience.
  12. Mendel Leisk
    38,243
    I just recently had the intake off, reworking my oil catch can install, and found straw cleaner brush was perfect, with a shot of brake cleaner, for those little capillaries.
  13. jburg
    jburg Member
    93
    RTP, NC
    Question: Are the intake manifolds on the 2012+ GenIII really redesigned?
  14. Mendel Leisk
    38,243
    I believe they did, and the change was:
    The old one went from a single large (EGR) gallery, into the four capillaries, whereas the new one goes from a single large gallery, to two intermediate size, and those each split into a pair of capillaries. I think... And I've heard it really didn't make any difference, and that makes sense to me: since the EGR clogs from one end to the other, woefully undersized, and the incoming gasses too dirty.
    #34 Mendel Leisk, Feb 24, 2020
    Merkey likes this.
  15. jburg
    jburg Member
    93
    RTP, NC
    I didn't think it would make that big of a difference and it will clog just as easily. I was just curious.
    I know for a fact that Toyota redesigned the EGR system to recirculate gases post-cat in the Gen IV. Makes sense: A cat burns most if not all of the junk before it gets through the EGR cooler and valve.
  16. ChapmanF
    15,098
    Not to mention that you can go look at a car for sale "with a clean Carfax", and take said car to a Toyota dealer for a look-see, and have said dealer show you how said car has been all collision-worked and re-straightened and re-painted from the guggle to the zatch and ask said dealer "so, this'll get reported to Carfax and help out the next potential buyer, right?" and have the dealer say "yep, we report every visit", and you can check back later on Carfax for the date of your visit and see the entry says "maintenance inspection completed".
  17. jburg
    jburg Member
    93
    RTP, NC
    I totally believe it. I have seen records that merely state "Vehicle serviced." That literally means nothing to me, it means that the technician or service writer was feeling particularly lazy that day.
    I actually suckered Carfax into calling me today. Guess you can say I am smarter than your average bear. I set-up a dummy account/trial on Workshop Software with a fake name and then transferred that data to Carfax to register my account and they called me in a few hours. Cornered the guy and had me transferred over to customer service. He told me, in fact, there is no way to enter service history data onto your service record without having a subscription (which I figured). When I first called today, they want regular consumers to e-mail them, not speak on the phone. Shops, on the other hand, have a direct option to speak to a rep.
    As above, I just hate shops telling me, "Ohh you are due for X" and I had just done it. Just because it's not on the service history doesn't mean diddly. Did you even look over the car, did you test the component, did I complain about poor fuel economy or a noise? This happened to me not too recently and the guy's reply was, "Well, any reputable shop will enter data into an SMS system that we can see." They suggested a brake cleaning on the caliper pins etc. and Toyota had done that 20 or 30k miles beforehand (when replacing the front and rear brakes) and guess what - this wasn't reflected on the service history because the technician just entered replaced rear pads and resurfaced rotors. The front brake service from a few weeks before isn't in our service history. The Carfax also doesn't reflect the fact that the head tech told my wife that she didn't need rear brakes only to have the rear calipers eat into the freakin' rotors 3 or 4 weeks later and then the service manager told her it was the road salt from Ohio that made the pads disintegrate and the lead tech would never overlook something like that (we were dating long distance at the time). They act like it's not possible for someone to do a good job if they don't have access to an SMS system.
    Honestly, the Carfax marketing campaign is great because I bought into the bull crap.
  18. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    I once cleaned 2 manifolds back-to-back at our meet ups, went through 5 brake cleaner cans. May have lost majority of my sense of smell without using a type of filter mask.
    pjksr02 and Raytheeagle like this.
  19. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    If they are the 2012 refresh model then yes. I have a refreshed model and got refreshed with the same issue, Toyota made sure refreshed ones don't get away with it either.
  20. jburg
    jburg Member
    93
    RTP, NC
    The straw cleaners worked like magic yesterday and it was disgusting in there and the partial blockage was definitely the source of the rattle in traffic. Thanks for the tip! Took the car on a 25 mi or so test drive and the MPG on the computer jumped from 46.9 to 48.9 and there was already 100 miles on the tank of gas. Think the old girl is back to her true form. I have been tracking mileage and we have jumped from 42.6 (this is with going through the mountains of WV and VA over the holidays) to 46.3 over the last 3 tanks and this includes cleaning and partial replacement of the EGR circuit. Last tank (post-EGR cooler and valve replacement), without addressing the channels was 46.8 calculated MPG - 47.4 computer.
    Also, I am curious about your repositioning of your OCC. Even though my oil burn is almost non-existent now and I have an OCC mounted behind the headlight, there was still a significant amount of oil in the intake manifold. Maybe a few ounces.
    I am thinking that the Atkinson cycle contributes to this build-up. I will be curious about your results. My OCC is mostly water mixed with oil and unburnt fuel (more like coffee).
