Water drain in back door clogged?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by FernandoRA, Feb 24, 2020.
  1. FernandoRA
    FernandoRA Junior Member
    Mexico
    When I first got my 2016 Prius, I would wash it and all the water ingested in the top of the rear windshield would come out through some slots in the bottom border of the trunk/windshield. Nowadays, after 3 years, water goes in but it does not get out and as soon as I open the trunk, a good amount of water falls from the between the glass and the chassis into the area when the trunk hinges are.
    Do you have any idea if there is a drain there and if it is, it might have gotten clogged with mini leafs and general dirt. Is there something that can be done to open the drain?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,041
    7,580
    near Brisbane, Australia
  3. FernandoRA
    Mexico
    alanclarkeau, I was under the impression that those are just rubber. Aren't the drains the little holes in the black plastic above the marked areas? (in green)
  4. alanclarkeau
    7,041
    7,580
    Oh - I never noticed them - it's dark outside now - I'll have a look in the morning.
  5. Mendel Leisk
    38,243
    Try running something up the drain, in particular after it's been raining, everything's softened up. Say a zip tie.
