Traction battery odd bolt 12mm
Discussion in 'Gen 2 Prius Technical Discussion' started by Bumblebeetuna, Feb 27, 2020.
  1. Bumblebeetuna
    Bumblebeetuna Junior Member
    30
    Adairsville GA
    There’s one odd bolt in the removal of the traction battery it’s 12 mm. I’ve removed two of these(traction batteries) and never paid attention to where this one bolt belongs???????
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,102
    5,812
    Columbia, SC
    It's called the grounding bolt. It goes in the fastener hole toward the front on driver side, fastening the battery case to the floor.
  3. Bumblebeetuna
    30
    Adairsville GA
    Thank you.....So, I think there’s 3 holes on the front I think. Furtherest to driver side hole? I decided on center in some lottery........hehehhe. Wonder if I messed anything up......
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
    If you are in the hatch facing the front of the car, the bolt goes in the hole on the left ( driver side), towards the front of the car.
    Not the end of the world if it doesn't go there. But annoys the heck out of me whenever I see it in the wrong place!
    Also tips me off that someone has been messing with the HV battery.
  5. strawbrad
    strawbrad http://minnesotahybridbatteries.com
    953
    996
  6. Bumblebeetuna
    30
    Adairsville GA
    You’ve caused me to question reality and I’ll have to put that wayward metal fastener in its proper home now.........so yes the clues have led you to someone and that is I. Lol. Thanks again!
