Which Wheel gets the most wear?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sherlockcrypto, Feb 29, 2020.
  1. sherlockcrypto
    sherlockcrypto Junior Member
    So I am checking my tires and I am noticing that the front driver's side wheel is getting the most wear. Is this normal? I am considered rotating the front wheel with the back wheel to try to balance out the wear. Is this advisable? I haven't been doing tire rotations in the past, but am starting to do them now. My car is at 42k miles with 0 tire rotations thus far and on stock GoodYear Assurances.
  2. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Do you check engine oil level also?
    dig4dirt and pjksr02 like this.
  3. Kenny94945
    Kenny94945 Active Member
    850
    425
    Sausalito
    2016 Prius v wagon
    Yes, normal.
    Tire that spins when the throttle is applied wears the most.
    Noting: If (if) all alignment specs are correct as sometime the inner or outer portion of the tires may wear more.
    Yes, front to rear tire rotation increases tire life.
    Check your owners manual and tire spec, cross rotation procedure is even better.
    So, tire pressure, alignment, rotating all effect tire wear.
    +1 yes check you oil too. :)
  4. bisco
    51,912
    I can’t measure a difference between front right and left
  5. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    :ROFLMAO:
  6. Mendel Leisk
    41,439
    Umm, yeah. Toyota recommends to rotate straight front-to-back, every 5000 miles. That said:
    At this point, it might best to just replaced those tires. What's the remaining tread depth on the front, in 32ths of inch (please, no Lincoln pennies). Putting worn down tires on the rear is usually not advised, you might get surprised when cornering.
    pjksr02 likes this.
  7. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Ruler or tape measure.
  8. pjksr02
    pjksr02 Active Member
    532
    227
    Connecticut
    +1 Those tires are nearing their end of life. If they're on your 2015, they are probably 6 years old.
  9. Mendel Leisk
    41,439
    And next set, play it smart: rotate them. Arguably, if you rotated every 10K instead of 5K it wouldn't make much difference, but no more than that.
  10. sherlockcrypto
    Yes - i am considering rotating my front driver side wheel to my rear passenger side wheel. I rarely have a passenger so that's why I am wondering if the driver weight is causing more wear on that side. Ihoping to get maybe 50k miles from these tires.
  11. bisco
    51,912
    i wonder if the left tires should get a little more pressure
  12. PosauneGuy
    PosauneGuy Member
    123
    91
    California, here I come...
    2025 Prius
    Agree with others above who recommend doing regular rotations after you have replaced your tires. If the front tires are more worn than the rear tires, you don't want to put the front tires on the back because of cornering issues mentioned above. (And if they're directional tires, then you cannot exchange the front driver side tire with the rear passenger side tire; directional tires need to stay on the same side of the car.) Wear out your current tires as they are, then when you get new tires, get on a rotation schedule.
  13. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,802
    2017 Prius c
    No, it is NOT normal to have only one tire wear a lot more than the others.
    With "normal" driving, NO tires should "spin" when the throttle is applied.......or all of them spin depending on your perspective.
  14. sam spade 2
    7,035
    2,802
    2017 Prius c
    AND have the alignment checked......because if one tire shows noticeably more wear, something is off.
    Even a properly aligned car often will show slightly more wear on the outside edges of the front tires.
    The key word is "slightly" and both fronts should be roughly equal.
