OEM 12V AGM battery replacement; how long post manufacture is still good?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by soitgoes, Mar 2, 2020.
Tags:
  1. soitgoes
    soitgoes New Member
    Pennsylvania
    The 12v battery needs to be replaced (was original to the 2009 car). After some research here (many thanks) I decided to go for the OEM battery as the Bosch was no longer in stock and the Optima did not present a cost savings.
    I picked up the batter from the dealer and when opening the box I see a manufacture date code 310719, indicating a July 31, 2019 manufacturing.
    Has this battery been sitting too long, should I request a 'newer' battery from the dealer?
  2. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    Are we talking about the hybrid battery or 12v?
  3. bisco
    52,303
    i had the same thing when i replaced mine last summer. i think it's fine. yo might want to put a charge on it, as the car does a poor job.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    best thing to do is bring a 12 volt DC voltmeter and test the battery right there at the counter. if its dead I dont want it. Its been sitting on the shelf dead for a year. Sulphation.
    The OEM's a re the best battery's but they need to be healthy. Lots of us put that new battery on a charger and make sure its full before installing it. Then once its installed you can do a minor load test on it. But that requires a voltmeter also..
  5. Mendel Leisk
    41,832
    Maybe have the dealership connect it to an electronic load tester, show you the outcome. IIRC the OEM is 325 CCA. If it's in good shape it should read well above that, say 375~390.
    My 2cents: It's good for both the seller and buyer to do this test as a matter of course, with every battery sale.
    I suspect it'll be ok, a battery carefully stored, without the relentless back ground loads it would have if installed in a modern car, can weather some shelf time.
    I'd second starting it off with a charging session. A smart charger, around 3 amp range would be good. Verify max amperage in Owner's Manual.
  6. soitgoes
    soitgoes New Member
    Pennsylvania
    I appreciate the helpful advice! I’ll looking pre charging and testing. I’m not sure that his battery will make it eleven years like the last one, but I do hope to have a long life!
  7. uart
    uart Senior Member
    4,220
    1,211
    Australia
    It should be ok.
    Do you have a voltmeter? Measure the open circuit voltage and tell us what you get.
  8. Mendel Leisk
    41,832
    If just reading voltage: start with a full charging session, with a smart charger, let it run to completion. Then drive the car a day or two. If possible pop the hood in the evening (to avoid any subsequent wake-up of the car's systems). First thing the next morning check the voltage at the jump point. A new AGM in good condition should read at least 12.7something volts.
    Voltage alone might be deceptive though, especially if the battery isn't initially recharged. A battery sitting on a shelf can be very viable, but it's voltage dropped a bit. The electronic load testers test voltage and the CCA. With a battery that's in good condition, just voltage lagging a bit (due to protracted storage), it may come back with stellar CCA, lowish voltage, and a verdict "good but charge".
    The dealership has these testers, just sold him the battery, should be willing to demonstrate it's viability.
    You can DIY such a test with Solar BA9, for example.
    #8 Mendel Leisk, Mar 3, 2020
  9. bisco
    52,303
    11 years is an exceptional run. the quality probably isn't that good anymore. figure an average of 6-7 years in your climate, all else being equal.
