2012 Prius good price?
Discussion in 'Gen 3 Prius Main Forum' started by Alex420, Mar 7, 2020.
  1. Alex420
    Alex420 Junior Member
    Glendora
    Hello, I have found a white 2012 Prius 2, one owner, 60k miles, very clean.
    $12.000
    I have checked the carfax for damage or odometer roll back, also have check KBB value. this is on Craigslist, Los Angeles area.
    I think it’s a good price because of the low miles. Similar 2015’s with the same mileage were $13.500 - $14.000
    Any problems with this year? I had a 2010 and dearly miss it (that was 3 years ago)
    Should I keep looking, or maybe hold out for a 2015?? Thanks all! Happy Saturday
    52,286
    Price seems high, but you can only go by what is available
    Only problem is the egr circuit. At 60k, you’re just in time to clean it out and add an oil catch can
    Tande and Bay Stater like this.
  3. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    It did seem high at first shock, but due to market it isnt so bad.
    Low mileage is nice.
    Is that private or dealer?
    How long have you been looking?
    Alex420 likes this.
  4. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    I'd spend the extra for the 2015.
  5. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Without test driving it, it only looks great on paper.
  6. bisco
    52,286
    Hybrids should be cheap in this market environment
    RMB likes this.
  7. Alex420
    Glendora
    Private party, asking 12.9
    Been looking for about 5 months
  8. bisco
    52,286
    Go for it!(y)
  9. jburg
    jburg Member
    93
    RTP, NC
    If you don't drive 20k/yr, it is not worth the extra money. Go find a traditional, low mileage ICE, that will be way cheaper. What about a low mileage Corolla or Camry? I was looking at a 2017 Camry with 20k miles for $14k and change. The only advantage of the Prii is fuel economy.
    Not to mention the known issues with the GenIII (Specifically most issues affecting 2010 to 2012 models)
    Premature headgasket failure (all GenIII)
    EGR circuit clogging (all GenIII)
    Oil burning (2010 to 2014)
    Brake actuator failure (at least 2010 to 2012)
    Others have noted CVT failures
    Etc.
    The GenIII Prius is NOT cheaper to own in the long run as compared to a traditional ICE.
    #9 jburg, Mar 8, 2020
    Grit likes this.
  10. 5 Speed
    5 Speed Member
    74
    83
    Santa Barbara
    With Oil headed to 20 a barrel if you can hold out a little I see the price coming down. The stupid oil market will again sell Americans big vehicles.
    Grit, RMB and bisco like this.
  11. jburg
    jburg Member
    93
    RTP, NC
    Ohh and I forgot inverter failure... So yeah, don't buy.
  12. jburg
    jburg Member
    93
    RTP, NC
  13. bisco
    52,286
    inverter failure?(n)
