Engine performance on top speed
Discussion in 'Gen 3 Prius Main Forum' started by Imrand, Mar 9, 2020.
  1. Imrand
    Imrand Junior Member
    Pakistan
    Hello everyone i need assistance i own gen 3 2011 for past 16 months it was ok till a month ago. I was on highway and speed was 180km/h its top speed as i have JDM version. Suddenly i had to reduce speed and I felt power loss after that day till now I can’t cross 165km/h what ever i do. Ni error code performance is excellent till 140 after that its very hard for engine to push. there is an other problem some times I notice my engine gets very hard as i have to too push gas and some time its very light. Suggestion please what should i do ?
  2. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
    why is the jdm version slower than the regular one?
  3. Imrand
    Pakistan
    All jdm are limited to 180km/h they do not allow above this speed. Now help in my problem
  4. bisco
    52,396
    Bad head gasket?
  5. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Thought I was demanding heh.
    StarCaller likes this.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    So 180 kph is about 112 mph for those of us on this side of the big water.
    and 165 is around 103?
    How long was the car running at 180kph when it started getting weak? Did the check engine light or any warning light come on?
    If it still feels normal up to about 140, I would look at items that would limit it on the top end. That would be fuel flow, air flow or ignition timing. Possibly (remote) even some type of failure in the exhaust system that's preventing full flow.
    I would imagine, that if it was a head gasket, at that amount of rpm/load, it would be spewing coolant out of the overflow tank or spewing heavy vapor from the exhaust. (at least that's what would happen on older engines)
    tvpierce likes this.
  7. Imrand
    Pakistan
    It looks perfectly fine.
  8. Imrand
    Pakistan
    Thanks for ur reply i will check it for sure but as per my check list. I already cleaned catalytic 2nd i am going to replace spark plugs. Also egr pipe is in my mind too as it was also pending during my last service. If still not resolved then i will go for gasket. Open for suggestions if any other important thing missing. One important thing one of my battery cell is also bad that is also in my target list to be replaced.
  9. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    How did you determine that?
  10. bisco
    52,396
    x ray glasss
    kc5dlo likes this.
  11. Imrand
    Pakistan
    ☹️You are right but please check as i said above I want to check egr pipe few days back i cleaned up exhaust manifold but egr pipe was pending but it was also in bad condition 2nd is plugs. Will it be help full or i go straight to gasket ?
  12. StarCaller
    1,279
    730
    just drive it & check your coolant level once in awhile /
  13. Imrand
    Pakistan
    As my understanding’i could be wrong’ gaskins should start producing overheating
  14. Imrand
    Pakistan
    Coolant level is perfectly fine up to mark and no issue.
  15. Mendel Leisk
    41,913
    How many kilometers on it?
    Have to say, 180 kmh is about 100 kmh faster than I ever go, lol.
  16. kc5dlo
    kc5dlo Active Member
    266
    163
    DFW TX
    2021 Prius
    Won't do 180 KPH? Sounds like everything is bad. You need a different car.
  17. Imrand
    Pakistan
    Well i got it fixed. Let me tell u wht i did, i cleaned EGR pipe which was blocked. And also replaced 2 cell in my HV battery pak.
  18. bisco
    52,396
    well done!(y)
  19. Mendel Leisk
    41,913
    To unblock the EGR air flow, you need to thoroughly clean all the highlighted items shown here:
    Hopefully that's what you've done? If not let me know, I can post some info and links.
