Tapping noise for first few minutes of driving
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ProspectivePriusPeruser, Mar 10, 2020.
  1. ProspectivePriusPeruser
    ProspectivePriusPeruser Junior Member
    Australia
    As the title says, ever since I've had my Prius I've noticed a tapping noise coming from the engine. I did an Oil & filter change but that hasn't seemed to change anything. It seems to go away or at least decrease in severity when I've been driving for a little while. Unsure if outside temperature seems to correlate with how long the noise lasts. I used 10W-40 Oil (it's what the prior owners used, presumably to stop it losing oil at its high mileage) The noise doesn't seem to happen if I'm just sitting with the engine running, only when it's moving the car. Any thoughts or suggestions?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,264
    15,514
    Bay Area, California
    2019 Prius Prime
    Was it ever run low on oil?
    SFO likes this.
  3. ProspectivePriusPeruser
    Australia
    Wouldn't know, the previous owners never mentioned anything about it being low on oil. It doesn't seem to be losing any oil for me. It has been about 3000km since I changed the oil and it's still in the same spot on the dipstick.
    I listened today and it definitely stopped after 5-10 minutes and sounded perfect, it wasn't like a separate tapping noise but the engine sounded 'harsher' if that makes sense. I'll try to record it tomorrow morning as I know my description isn't great.
    Raytheeagle likes this.
  4. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    Does Gen2 retard/advance the timing like "c" and Gen3?
    That might be what you are hearing
  5. Priuslover09
    Priuslover09 Member
    365
    48
    Dc
    I think it’s the muffler
  6. ProspectivePriusPeruser
    Australia
    Definitely temperature dependent, starting the car at 9c gave me heaps of the noise whereas at 23c it sounded fine straight away. Couldn't record the noise due to this haha. Next cold morning I'll have to remember to record it.
    I do have a rattly heat shield from where I scraped on my driveway the first day of owning the car (I now kick out passengers prior to entering my driveway) so could be related, though the noise that makes is very distinctive and only happens at certain rpm regardless of temperature.
