Featured Sad Catalytic Converter theft news
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Marine Ray, Feb 21, 2020.
  1. PriusCamper
    PriusCamper Senior Member
    13,108
    5,312
    Pacific Northwest, USA
    All I know is in the article... But Prius are the most popular because they wear out slower due to hybrid efficiency, so are most sought after/profitable by the criminals who take them apart and extract the valuable material...
  2. fuzzy1
    10,603
    While the catalyst function may wear out due to clogging or a covering layer, these metals don't "wear out". Unless they somehow erode away, which I haven't heard of, the metal refiners can still extract them all even from a completely "worn out" cat.
  3. Leadfoot J. McCoalroller
    8,153
    7,656
    Pennsylvania
    2018 Prius c
    The valuable catalyst materials are originally coated onto a honeycomb or latticework. If the assembly is overheated, the structural honeycomb can melt, slump, droop, or even get blown out the tail end in droplets, carrying the catalyzing layer along with it.
    You'd need a very fuel-rich condition like an injector stuck open to get it that hot. Rare, but it does sometimes happen.
    fuzzy1 likes this.
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,513
    2,503
    Taylors, SC
    In that condition, the rear oxygen sensor will definitely throw an OBDII error code.
  5. hill
    8,940
    the Jack you used to lower that low would either be stuck, allowing the thieves to use that Jack, or the jack that could get so low and still be pulled out? Yeah, that's the Jack the thieves would use next
    calif requires thumbprint & CA driver's license in order to sell a cat. it only helps a little.
    not NO problem .... a different problem;
    $1,000's in 480v main Breakers ripped off from supercharger cabinets out of the station linking SoCal and Vegas
    [Updated] Tesla Supercharger connecting LA to Vegas vandalized ahead of Thanksgiving weekend
    Stealers gonna steal
    #45 hill, Mar 13, 2020
  6. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Who's Jack? :D
  7. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    But isn't it possible to get something like a corolla, or Yaris catalytic converter, measure dimensions, then weld it there?
  8. Leadfoot J. McCoalroller
    8,153
    7,656
    Pennsylvania
    2018 Prius c
    It is possible, yes. That would get the car going quietly again.
    However, in California the car will be inspected every year. If the inspector finds anything other than the original parts, the car fails and can't be operated. The inspectors in California are very strict in comparison to most other places. That's why this is such a big problem there, when it wouldn't be a big deal in many other places.
    Dxta likes this.
  9. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    Haha! That's like when I was a youngster watching old cowboy movies: "Shoot at Will". Who's Will, what did he do that everyone should shoot at him only, and the biggie: I never heard of an Indian named "Will"!
    telmo744 likes this.
  10. bwilson4web
    16,389
    There are two O[2] sensors on each side of the converter to measure the effectiveness of the catalytic converter. If they fail, you get a check engine light and a code.
    Georgina Rudkus likes this.
  11. Georgina Rudkus
    3,513
    2,503
    Taylors, SC
    One front and one back to compare before the CAT and after the CAT to determine efficiency.
    bwilson4web likes this.
