Donut Spare Tire
Discussion in 'Gen 4 Prius Main Forum' started by 0356kid, Mar 12, 2020.
  1. 0356kid
    0356kid Junior Member
    california
    Have a new 2020 Prius XLE AWD (no spare tire) and looking for a source that might offer a donut spare tire for extended trips. Stock rims are 15” if that matters. Thanks....
  2. pianewman
    pianewman Active Member
    264
    183
    DallasFortWorthTEXASregion
    2018 Prius
    Welcome to PriusChat. Your question has been discussed at length in previous threads.
    New wheel (dealer) is pricey, $120, w/o a tire.
    Depending on where you live in California, you can probably find one at a junkyard.
    Or... go to car.part.com. (CORRECTION: car-part.com) They have a nationwide database. There might be a source near you. (there's a wheel available in a Houston auto recovery dealer, called Almeda, shipping probably isn't cheap)
    #2 pianewman, Mar 12, 2020
    krmcg likes this.
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    It doesn't matter. The Toyota "donut" spare is 15-inches, whether your car comes with 15- or 17-inch original wheels.
  4. pianewman
    264
    183
    2018 Prius
    The following numbers are for 2016-2019 Prii. I'm not sure if they apply to the 2020 AWD version. You'll have to cross-reference them on a Toyota parts site.
    You'll need all of these parts to complete the mod, putting the spare tire under the floor.
    Spare Tire Donut; T125/70D17 98M - (tire size, on the OEM 17" spare tire rim)
    Carrier (Spare Tire Retainer) Toyota P/N 51931-47010 (hold-down bolt, bracket is already welded to the trunk floor)
    Box, deck floor LH Toyota P/N 64997-47050
    Box, deck floor RH Toyota P/N 64995-47040
    Box, deck floor (Center) Toyota P/N 64993-47090
  5. 0356kid
    california
    Thanks to all with suggestions - will check it out.
  6. Mendel Leisk
    41,609
    Well, the temp spare is either 16" (3rd gen) or 17" (4th gen), and either will do. The 16" 3rd gen option is more-or-less identical in outside diameter to 195/65R15 stock tire, while the 17" is oddly smaller, at least 2~3% IIRC. Bit of a puzzle why they changed.
    I would go with 3rd gen:
    Gen 3 temp spare info:
    rim p/n: 42611-20841
    tire spec: T135/80D16 101M
  7. 0356kid
    california
    Thanks Mendel - very informative.
  8. FuelMiser
    1,349
    929
    Monument, CO
    I stand corrected, and I apologize for the error. The donut spare in my '16 Three Touring is in fact 125/70D17
  9. A440SPS
    A440SPS Junior Member
    Albuquerque NM
    Will these parts work for a 2019 eAWD Two? I read elsewhere here that the rear electric motor takes up the wheel well space. Thanks!
  10. Mendel Leisk
    41,609
    Unfortunately no; Toyota engineers didn't break-a-sweat locating the AWD rear wheel components:
    A440SPS likes this.
