  1. frodoz737
    frodoz737 Top Wrench
    4,711
    2,513
    33
    It's Saturday, so I left it at home...and cruising my ZR1.
  2. RightOnTime
    RightOnTime Senior Member
    790
    1,660
    183
    Kidnapped in OC, CA
    @ccaudio1 - check your Engine coolant level. With it being that low, you may be experiencing headgasket issues
    iPhone ?
  3. ccaudio1
    ccaudio1 Member
    51
    37
    CA
    2013 Prius v wagon
    Thanks. Topped it off I did a full cleaning of the egr the other day and didnt have enough coolant to fill it to the max line at that time
    #18023 ccaudio1, Mar 9, 2020
    RightOnTime and TheeWood like this.
  4. FST4WHT
    FST4WHT Junior Member
    Sacramento, CA
    The original plan and end result. Cool idea at first but I've decided to just save up for a decent Android double din. Screenshot_20200314-101710.jpeg Screenshot_20200314-101635.jpeg
  5. ccaudio1
    ccaudio1 Member
    51
    37
    CA
    2013 Prius v wagon
    They are red now.. much better than the clear. Waiting for it to dry and will apply clear to finish up. 20200314_135006.jpeg
    #18025 ccaudio1, Mar 14, 2020
    JoshM, Montgomery, Johnsk93 and 6 others like this.
  6. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
  7. frodoz737
    4,711
    2,513
    33
    Drove it. It's raining and I didn't want to pull the ZR1 out of the garage. ;)
  8. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
    right, a ZR1 might be better suited for sunny days /
    Burna J likes this.
  9. ccaudio1
    ccaudio1 Member
    51
    37
    CA
    2013 Prius v wagon
  10. frodoz737
    4,711
    2,513
    33
    It is! ;)
    Burna J and ccaudio1 like this.
  11. ccaudio1
    ccaudio1 Member
    51
    37
    CA
    2013 Prius v wagon
  12. StarCaller
    1,279
    730
    I see, time to show the toys..... ;)
    ducati monster, gto 6.0
    ccaudio1 and Raytheeagle like this.
  13. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    What's that supped up vacuum cleaner sitting in the corner:sneaky:.
    Nice barn too(y).
    Montgomery likes this.
  14. StarCaller
    1,279
    730
    new mexico is pretty dusty, especially if you live on an unpaved road in the mountains....
    & if you want things nice & clean a regular vacuum isn't cutting it, so for normal the gto is covered....
  15. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    So now you have red reversing lights and a license plate illuminated in red!? What were you thinking?
  16. Grit
    Grit Senior Member
    6,573
    4,228
    Wilkes Land
    Had a feller that came on here and modified his tail lights, said there was too much red in them so he used another color to cover up the red and installed red bulbs. Safety is not a priority here :whistle:
  17. ccaudio1
    ccaudio1 Member
    51
    37
    CA
    2013 Prius v wagon
    The reverse LED light works just fine in red. It looks a lot darker in the picture. Still very bright. Also the license plate light are brighr white didn't color the cover. The other light is the 3rd brake light since it was clear.
  18. SnowMexicanuck
    56
    66
    Quebec, Canada
    (b) Backup lamps shall be so directed as to project a white light illuminating the highway to the rear of the vehicle for a distance not to exceed 75 feet.
    My first concern about the full red tint was the legality... That line above is from California code, so unless it's outdated, it's not legal.
  19. MPGRaja
    MPGRaja Senior Member
    469
    1,680
    Corona
    B-Day gift
    Time to install and see if anything improved or not.
    Putu Ariawan likes this.
  20. ASRDogman
    ASRDogman Senior Member
    7,758
    3,967
    What is this??
    TheeWood likes this.
