new 08 prius owner
Discussion in 'Gen 2 Prius Main Forum' started by richard203, Feb 21, 2020.
  1. richard203
    richard203 Member
    268
    57
    SF
    alright so i just bringed to the shop they checked for leak and didnt see any so they went ahead and vacuum and charge the a/c system and the noise went away and the a/c is ice cold now. they say they tested the system when they pressureizing the system and the number did not drop thats another sign theres no leak in the system thats what they say so let see in a couple month and see if the a/c still ice cold.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    Yay! But there has to be a leak or you would not have lost the coolant to begin with unless vandals got in under the hood and vented it through one of the Schrader valves. It's just such a small leak that the shop could no detect it, I guess. You'd think their sniffer would have detected something. Anyway, if it's that small of a leak, it should be quite a while before it gets low again. (y)
  3. richard203
    richard203 Member
    268
    57
    SF
    i think the car have been to a front end crash cause 1 of the headlight looks new and the other is old. and the bumper wasnt aligned well. mybe the condensor was damaged and replaced but didnt recharge the a/c?
  4. richard203
    richard203 Member
    268
    57
    SF
    so my meter went off again when its cold, im trying to order the meter and forgot whats the actual mileage was is there any way to see the odometer milage?
