double tap for charger release
Discussion in 'Prime Main Forum (2017-2022)' started by smyles, Mar 17, 2020.
  1. smyles
    smyles Active Member
    332
    229
    US
    2020 Prius Prime
    My '20 requires two pushes of the charger release button to let it go. On 1st push something else (charger door lock?) clicks, on 2nd it's the charger lock itself. Prior Primes required a single push. I wonder if I messed something up during coding w/Carista, although there's nothing specific to charger door/lock in its menu options.
  2. schja01
    schja01 Senior Member
    1,837
    1,222
    Chicagoland
    2024 Prius
    Limited AWD-e
    Which button are you referring to? The oval one with the LED or the release on the charging cable handle itself?
    I use the latter which only requires one push
    Personally I don’t know when I should use the oval one with the LED.
    jerrymildred likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,153
    Tampa, FL
    I can't fathom why the charger door lock would click. Kind of hard to plug in the charger if the door is locked and just as hard to close it if the EVSE is plugged into the port. Very mysterious. A cursory scan of the owner's manual didn't show anything.
  4. smyles
    332
    229
    US
    2020 Prius Prime
    this button:
  5. jerrymildred
    11,517
    14,153
    Tampa, FL
    Ah. THAT one! I never use it. Sorry.
    edit to add: but I think I did see something about settings for that in the manual.
  6. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Unless you have auto-lock always active, that first push is to lock and the second to unlock.
  7. schja01
    1,837
    1,222
    Chicagoland
    2024 Prius
    Limited AWD-e
    I never use it. That said I only charge in my locked garage.
  8. Washingtonian
    Washingtonian Senior Member
    726
    621
    Not only do I never use it, I didn't know it was there. I've learned a lot on this forum.
  9. Trollbait
    12,575
    I don't think all the trims got the charger lock.
  10. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    As obvious from the responses everyone are giving, that function is such useless feature in upper trims (Premium and Advanced or XLE and Limited). I don't miss not having that button on my 2020 LE (swapped from 2017 Premium).;)
  11. Tideland Prius
    16,563
    lol. I must the only one who uses it.
    Because I only have an outlet, I carry a portable EVSE. Therefore, I rely on the smart charging cable lock to at least deter or delay theft of my EVSE.
    I have mine to auto-lock upon insertion but manual unlock. (You can have it manually unlock upon full charge if you use a public charger, so that others can unplug your car when it's full and start their charging instead of waiting for you to return).
    Back to the OP's question, it must be a new feature for 2020? That double tap to release is slightly more convenient than pressing the unlock button below then releasing the charging cable)
  12. smyles
    332
    229
    US
    2020 Prius Prime
    No, it's annoying as f##k. Instead of once, you have to press the same button twice. And, as they say, who got'time fo dat??
  13. GSK
    GSK Active Member
    169
    107
    Baltimore, MD
    I use that lock all the time. Only requires one push to unlock.
  14. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Yep only one push on our 2020, same as it was on our 2018.
  15. smyles
    332
    229
    US
    2020 Prius Prime
    Solved: user error :)
    Being used to diff. setting, I didn't realize it was set to unlock upon completion of charging. So when my 1st press would actually lock it.
  16. DavidA
    2,345
    1,821
    Chicago western burbs
    For me it takes two quick successive presses to remove the charger handle (if the car is not fully charged). But I do have to remove the handle immediately after the second press, and I mean immediately.
