defrost buttons front/rear
Discussion in 'Gen 2 Prius Audio and Electronics' started by Sallyles, Jul 30, 2016.
  1. Sallyles
    Sallyles New Member
    Chino Valley Az.
    I
    The Vent/defrost/front/rear buttons on the steering wheel quit working so I replaced them, still not working, so I replaced the Clock spring, still not working. The controls on the touch screen works fine its just the steering wheel buttons that don't work. Anyone have this problem on their 2008 Prius?
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,056
    539
    Tucson, AZ
    2021 Prius
    I lost the function of those buttons also, and just assumed it was the clock spring. I traded the car in on my 2011 before I could find out for sure. My MFD buttons also worked just fine.
  3. bisco
    51,994
    does the clock spring connect directly to the back of the mfd? is it oem?
  4. Sallyles
    Sallyles New Member
    Chino Valley Az.
    I
    The Clockspring is inside the Steering wheel shaft, behind the steering wheel. Yes it is oem.
  5. Marty2go
    Marty2go Junior Member
    39
    Ohio
    Four Touring
    Had this same problem. Steering w buttons don't work only on right side. The left side ones work good. Changed the clock spring with no change so I changed the steering w. Then the cruse light would lite but not work. The recycle, F defrost, R .defrost, and cruse buttons don't work.
