2nd tank 57 mpg,
Discussion in 'Gen 2 Prius Fuel Economy' started by eaparicio, Sep 25, 2006.
  1. eaparicio
    eaparicio New Member
    I filled up for the second time today and the average mpg on the display was 56.2 for 374 miles driven :) I pumped 7.9 gallons in to fill the tank. The actual mpg compted is 47.3 which is an 8.9 difference. There was an 9.0 difference on the first tank. Is this normal? Which is probably the most accurate?
    I am estatic with the mpg I have been able to achieve so far. If this keeps up I just might be able to reach 60 on this tank. I actually think the city portions of my daily commute help to bring my mpg up a little. :D
    Ellen
  2. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    You'll need to gather a few more "data points" before you can really say... most people see up to a 2-3 MPG difference between the computer and calculated. With the car being so new, it's possible that the bladder is stretching out a little with each pump, meaning you're putting more gas into the car than you actually used. Give it a good 5-10 tanks and look at the average difference after that, see if the number starts going down.
    If it continues to be such a large difference, try filling up at a different station for a few times... it's possible that the pump you're using is misscalibrated, rading slightly higher than whats actually going in... but it really is too early to tell, given the inaccuracies of the bladder.
  3. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    Averaged over 40K miles of record keeping (yes, it's a weighted average), my MFD reads 1.7 MPG higher than actual.
    However, on a tank to tank basis the difference can be huge because the fillups are so variable.
  4. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    <div class='quotetop'>QUOTE(Tempus @ Sep 28 2006, 08:04 AM) [snapback]325031[/snapback]</div>
    Over the first 16k miles I'm in the same ballpark. My MFD reads 1.1mpg (or 2.4%) higher than actual.
  5. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Also note that outside air temp can really play Old Harry with your calculations on a tank by tank basis. If you live somewhere with large temp swings you'll find that your calcs are wildly off because the bladder has become more elastic or less so since your last fill up. Like other folks have said, over the long haul these sorts of variations should average out.
  6. eaparicio
    Thanks for the replys everyone. The bladder is something so new to me that I can see it is going to take me a little while to understand how it changes. I am used to the fuel tank holding what it is stated to hold. The temps. in DE can vary widely from early morning to late afternoon and from day to day. I am keeping track of my milage so I will see what the averages are over the next few tanks. I just hit 1000 miles on the odometer today. My MPG is sitting at 54.2 so I am a happy camper. :)
    Ellen
