Aftermarket wheel problems on 2017 Prius
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Pixelriffic, Mar 6, 2020.
  1. Michael N Bennett
    Michael N Bennett Junior Member
    Campbell River, BC
    ----Canada----
    You are welcome.
    Have a look at the "Toyota Certified" document that should be will your paperwork.
    If you want to keep the 17" size, the 2014-2019 Corolla sedan was available with a 17" wheel on the S trim level from the factory. You should be able to find a set of those at a recycler for $300-$400. They would look nice on a white car. Here is an image below.
    krmcg likes this.
  2. mathmantp
    mathmantp Junior Member
    montreal, canada
    2021 Prius PHV
    Are you looking to sell the Prius Plug-in rims? What size? I'm looking for a set of rims to install my winter tires on.
  3. Mendel Leisk
    41,893
    No, they couldn't be pried from my cold/dead fingers. :D But I still have to figure out an application for them.
  4. PaulDM
    PaulDM Active Member
    616
    319
    UK
    2022 Prius
    Excel
    Sounds like. Tyre balance issue rather than a wheel problem. I’m amazed that after market wheels in the USA are revered as dangerous at the get go.
