Average repair cost for front bearings?
Discussion in 'Gen 2 Prius Main Forum' started by GTW, Mar 25, 2020.
  1. GTW
    GTW Junior Member
    55
    Castroville
    Good evening. I hear a low rumble when making a turn to the left, it disappears when wheel is straight. It is not a clicking sound (CV), so I'm thinking it could be a passenger-side wheel bearing. To my knowledge there aren't any hybrid shops nearby. Any idea of the cost for this type of replacement? I wouldn't know if I was being overcharged or not. Thank you.
  2. Elektroingenieur
    2,515
    3,288
    Three Touring
    Without having heard the noise, I can’t say whether the proposed repair would fix it. The parts and labor cost depends on whether it’s the front or the rear; there are many previous threads, some of which discuss costs.
    For the front, one edition of Toyota’s Flat Rate Manual allows 2.7 labor hours (operation number 434021; NHW20 series). The required parts and list prices at this writing:
    Front Axle Hub Sub Assembly (LH or RH), 43510-47012, $231.43
    Front No. 1 Wheel Bearing Dust Deflector (LH or RH), 43246-47010, $23.42
    Hub Nut, 90177-22001 (90080-17238), $10.26
    Clip, 90468-16029 (90468-A0003), $1.01​
    For the rear, it’s 1.1 hours (421041), and just one part:
    Rear Axle Hub and Bearing Assembly (LH or RH), 42450-47030, $385.96​
    I’m assuming only one side would be replaced. Doing the other side at the same time requires the same parts and adds 1.0 (front; 434021A) or 0.3 (rear; 421041A) labor hours.
    The actual cost would depend, of course, on the hourly labor rate; whether the shop uses Toyota’s labor times or another estimating source; and the parts brand (Toyota or aftermarket) and markup or discount.
    There’s nothing hybrid-specific about this repair, by the way, but I’d suggest using a shop that has a Toyota Techstream diagnostic system, so they can check the wheel speed sensors after reconnecting them.
    SFO likes this.
  3. oldtechaa
    oldtechaa Active Member
    336
    225
    NZ
    2013 Prius Alpha
    My car also hums around left curves. I expected the passenger side bearing to be bad, so I got a quote from my local hybrid shop for $365 for one side. I replaced it myself for significantly cheaper, and had fun doing it. From what I've seen though, that's a pretty typical price for a hub. Turned out, that may have helped some, but I still have a hum, so I'm actually changing the left side tomorrow.
  4. GTW
    GTW Junior Member
    55
    Castroville
    Wow! I had no idea regular people had access to that specific information. Thank you so much for giving me something to compare apples to apples.
    Now I can seek a couple of different estimates knowing what a realistic rate should be. Thank you again
    Elektroingenieur likes this.
  5. GTW
    GTW Junior Member
    55
    Castroville
    If you don't mind my asking, did you replace just the bearing set or a complete sub sembly? Thank you.
  6. oldtechaa
    336
    225
    NZ
    2013 Prius Alpha
    I think as an integrated hub, there is no practical way to replace just the bearing. The hub itself is only $40-$100 from RockAuto or Detroit Axle, so trying to do just the bearing would be a ton of work and require the proper press.
    The prices of the Toyota parts as listed in the manual are outrageously expensive as well. The $100 hubs from RockAuto are SKF, Timken, Moog, or comparable high-end brands. An axle nut is only $3-5 online. I didn't replace my dust deflector and I'm guessing the clip is probably the tie-rod end nut clip?
  7. ChapmanF
    18,877
    Condensing from another post with more information, if you look closely at how a hub bearing assembly is put together, you'll see why it isn't going to press apart like granddad's wheel bearings, and isn't even a matter of the proper press.
    That said, there seem to be aftermarket replacements that look about the same from the outside but are built out of off-the-shelf bearings pressed together. If the "hub" has already been replaced once with one of those, then there might be a chance of pressing it apart and changing those bearings.
    pollypocket53132 likes this.
  8. GTW
    GTW Junior Member
    55
    Castroville
    Thank you for this illustration and the reference. I bookmarked that thread in regards to this conversation.
    You struck a good nerve with the Grandad reference. My Grandpa was a machinist, probably did this kind of axle-grease work a lot more than I will ever know. Thank you.
  9. oldtechaa
    336
    225
    NZ
    2013 Prius Alpha
    Axle grease is right, except in my case it's tie-rod end grease. I just replaced my left front hub today, and found that, probably while I was working on it, the tie-rod end boot came unsealed and started dumping grease out, so I'll replace that next week. My hub took a whole lot of hammering and penetrant spray to get out of the knuckle.
