Maintenance for a 2010 Prius at 25,000 miles?
Discussion in 'Gen 3 Prius Main Forum' started by Elliott Jaffa, Mar 27, 2020.
  1. Elliott Jaffa
    Elliott Jaffa New Member
    Arlington, VA
    My friend has a 2010 Prius and is due for her 25,000 maintenance.
    What is required or really necessary and what is the dealership going to upsell her to do that her car really does not need?
  2. bettergolf
    bettergolf Active Member
    403
    331
    Sanford NC
    Look in the owners manual and it will tell you what is required and when.
    SFO and Grit like this.
  3. Mendel Leisk
    38,106
    The Warranty and Maintenance Guide will.
    Has it had an occasional brake inspection? Tri-yearly (or 30k miles) is recommended. If it's never had an inspection, it's time. Not just the visual, a pull the caliper off inspection. If considering DIY (or anyone other than dealership) let me know, there are a few gotchas with the Prius.
    Also ten-yearly (or 100k miles) is the engine coolant change.
    Not in the US schedule but worthwhile: brake fluid change and transaxle fluid change.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,780
    2017 Prius c
    Pretty sure that brake fluid change is recommended every 3 years......but no fancy additional "flushing" is needed.
    And I personally would NOT be changing the transmission fluid with only 10K miles on it.
    Important note:
    Being 10 years old, if it still has the original tires on it, THEY need to be changed......regardless of how good they look.
    I have found that if I tell the dealership that I only want done what is REQUIRED and not to add on any extras that are not in the "book", they will honor that. Maybe I've been lucky.
    pjksr02 and Mendel Leisk like this.
  5. bisco
    48,862
    i have never done anything to our 2005 dodge dakota with 28,000 miles except drive it
  6. Mendel Leisk
    38,106
    Do you mean Toyota USA says tri-yearly brake fluid change. Not that I've seen. Toyota Canada does (tri-yearly or 48K kms), since around 2014.
    The car has 25K miles, not 10K. Regardless, just my 2 cents, and just judging from the colour of drained fluid: a first transaxle fluid change, around 1 year or 10k miles, is worthwhile. Cost about $40 to DIY, and takes maybe an hour.
    Good point. Funny thing, I've got some snow tires with about 10 years now, and I maybe will change them based on that edict, but I'd feel better about it if they'd at least looked like they needed changing: they look "mint".
    GET YOUR DEDICATED SNOW TIRES NOW !!! | Page 18 | PriusChat
    #6 Mendel Leisk, Mar 28, 2020
    Ed Beaty and dig4dirt like this.
  7. ChapmanF
    14,980
    Most important on a 25,000 mile 2010:
    TURN OFF THE TIME MACHINE before the odometer rolls back past zero and the car disappears.
    Borninblue, Mendel Leisk and Ed Beaty like this.
  8. 3PriusMike
    2,933
    2,286
    Silicon Valley
    Wow! 28,000 miles on one tank of gas?
    Mike
    Raytheeagle likes this.
  9. bisco
    48,862
    it's got a hemi!:cool:
