OEM EV Switch
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Zephyr, Aug 8, 2004.
  1. Zephyr
    Zephyr New Member
    Long Island, NY
    I am looking to do the EV switch mod and would really like to use the OEM switch that is used in Japan/Europe. Does anyone know how/where I can get one locally?
    Thanks,
    Mike V. <><
  2. callinectes
    callinectes New Member
    Huntersville, NC
    There is one on ebay right now... just search prius
  3. Zephyr
    Zephyr New Member
    Long Island, NY
    Thanks!
  4. mdacmeis
    mdacmeis Member
    133
    Michigan
    2018 Prius Prime
    Otherwise you can order from Japanparts.com. You send them the two part numbers and they send a quote, including delivery and currency adjustment to you. They do have a surcharge for credit card use but I still got mine in a week from them for about $52 delivered.
  5. Eisenson
    Eisenson New Member
    142
    I did the mod with an OEM-type rocker switch at first, but then modified the modification to use the light switch (purple wire). MUCH better! No hunting or feeling around, very natural.
    Also, if you have a few feet of scrap wire laying around, it's free.
  6. grijzen
    grijzen Junior Member
    Antwerp Belgium
    You can buy it to install by yourself.
    See "www.coastaletech.com"
  7. Eisenson
    Eisenson New Member
    142
    Not exactly. That's Coastal's lovely mod that puts EV control on the CRUISE CONTROL LEVER on the right side of the steering wheel. It's probably the easiest EV modification you can do, and is "stealthy" - no dealer will ever notice it.
    The mod I'm talking about was "given away" by Coastal (like so many other modifications). I don't remember where they released the information, but it puts the control on the LIGHT CONTROL LEVER on the left side of the steering wheel. It's more difficult, and a true geek prefers the additional challenge.
  8. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    I did the headlight flasher EV mode and it is sooo COOL! Wasn't too bad an install either, just have to take your time. Patience is needed whenever any wires are being dealt with. I LOVE that I can force an EV mode (under the proper conditions). The car WON'T go into EV mode unless certain conditions are met first, so the system 'protects' itself. I've noticed no change in MPG overall (have just over 1,200 miles since doing the mod). But it is cool to just pull the flasher lever and beep you're in! Drive fun, drive clean, drive Prius!
