Clunking/pop noise when braking
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Edwin Flores, Apr 9, 2020.
  1. Edwin Flores
    Edwin Flores Junior Member
    Palmdale, California
    Hi. I have a 2010 Prius. Has just over 200,000 miles on it. Every time when I first accelerate from a cold start and brake, I heard a loud clunk or pop sound. But it is not constant or happens consistently. After the first time I heard the noise and brake again, I don’t heard it even after I brake pretty hard. It won’t happen again until after I drive a little fast or take a tight turn or go over some bad bumps on the road. But sometimes even then, the car won’t make the noise.
    I may heard it about 2 or 3 times during a 30 to a hour long drive.
    I have looked up a few dozen videos about everything from loose braking pads, to bad steering knuckle, to bad lower ball joint, to a bad cv axle. The symptoms that were explained in every video doesn’t match up to what I’m experiencing.
    I have spare parts to change out just about everything that I have listed but wanted to make sure what that noise is coming from.
    If anyone knows what the problem may be or has any input, it will be much appreciated.
    kenoarto likes this.
  2. Rebound
    Rebound Senior Member
    3,996
    2,643
    Portland, OR
    That’s common with many disc brakes.
    The brake pad is a crescent-shaped piece of metal inside of a holder. For example, you back into your garage. Then the car cools way off... the metal shrinks a little. You start the cold car, put it in drive, and it rolls forward. The cold brake pads roll forward, and make the clunk sound. Then they warm up and expand within their carrier.
    It happens on many vehicles. But if the sound is new, I suggest you inspect your brakes. There’s a video from NutzAboutBolts on brake pad replacement that’s easy and comprehensive. Not hard at all!
  3. Mendel Leisk
    41,234
  4. Edwin Flores
    Thank you for the quick response. This noise is fairly new. It first start about a couple of weeks ago. I did replace my rotors and pads about 4 or 5 months ago but I never had a problem with them until, possibly, now. Could it be that the clips that hold the pads are loose or something?
  5. ttou68
    ttou68 Active Member
    351
    211
    Have you looked into your linkage? A bad linkage could cause clunky noise...
  6. Edwin Flores
    I just figured out what was the problem. The three bolts that hold the lower control arm and the lower ball joint together were loose. I just put some loctite and tightened them to spec and the noise was completely gone. They weren’t too loose but just loose enough to make that clunk noise.
