Trunk battery hold down
Discussion in 'Gen 2 Prius Main Forum' started by Papers, Apr 8, 2020.
  1. Papers
    Papers New Member
    Denver Co USA
    Just bought my daughter one of these little cars and upon inspection there is nothing holding the battery in the trunk in place.
    Tried searching but I keep coming up with universal hold downs, any help would be appreciated.
    49,568
    welcome!
    ask a dealer parts dept. or try online like camelback toyota
  3. qmanqman
    qmanqman Active Member
    313
    112
    CO
    dig around where the spare tire is. some clown may have thrown it in there and forgot about it. otherwise you're probably gonna have to go dealer of junkyard. there aren't even any Prius' in our local junkyard.
  4. Mendel Leisk
    38,775
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,261
    5,957
    Columbia, SC
    If I remember correctly, the entire battery mount assembly can be purchased new from Toyota for about $28. There's two versions, one for SKS cars and one for non-sks. The SKS cars have a slightly larger battery with a S46B24R model and the non-sks uses a S34B20R model.
    If you have the bottom portion already, which the battery sits on, the top arm is available for about $11
    2007 Toyota Prius Battery Hold Down. Clamp, Battery Hold Down. Support, BATTER - 7448047010 | Brewer Airport Toyota, Moon Township PA
    ydpplqbd and Mendel Leisk like this.
  6. Papers
    Papers New Member
    Denver Co USA
    Thanks all really appreciate the help
