Oil leak on plate next to exhaust manifold
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by oldtechaa, Apr 10, 2020.
  1. oldtechaa
    oldtechaa Active Member
    336
    225
    NZ
    2013 Prius Alpha
    First off, a disclaimer that this isn't technically about a Prius. It's actually about a Corolla, but it's essentially the same engine as the 2ZR-FXE. Here's a picture.
    To the right of the exhaust manifold, two bolts can be seen holding a plate on. Everything from that plate down is covered in oil. Does anyone know what the plate is?
  2. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    The picture is a bit dark, but I see both engine oil and possibly cv boot grease. Before continuing, I recommend degreasing and pressure washing the area.
    Most likely, it is seepage from the timing cover but there have been some reports of oil seepage from the timing chain tensioner gasket. The timing chain tensioner gasket is metal so the likelihood of oil seepage/leakage is very low.
    Raytheeagle likes this.
  3. Mendel Leisk
    41,865
    I think that plate with the two bolts is the timing chain tensioner? It sure looks the likely source. Do you know it's ever been removed? I recall in the latest Gasket Master video they say to replace its gasket or risk leaks.
    athlete11 likes this.
  4. The Critic
    3,193
    2,333
    CA
    Why would a metal gasket leak?
  5. Mendel Leisk
    41,865
    Don't know, but pretty sure they said something about that.
  6. oldtechaa
    336
    225
    NZ
    2013 Prius Alpha
    Thanks for all your comments. It looks like it is the timing chain tensioner, but according to a video online, which looked very much like the 2ZR-F(X)E, it is a simple rubber o-ring gasket. That's the highest point you can see oil, although the highest point I could see oil actually dripping while the engine was running was the electrical connector (probably a sensor) below the connector in the lower right of the picture. I do not know if it has ever been removed, but it looks like it's not uncommon for it to start leaking.
  7. The Critic
    3,193
    2,333
    CA
    The 1ZZ-FE's (old 1.8L in 03-08 Corolla) used an o-ring on the timing chain tensioner. The 2ZR 1.8L (09+ corolla) used a metal gasket, part # 135520T020.
  8. oldtechaa
    336
    225
    NZ
    2013 Prius Alpha
    Yeah, I was just looking it up, and I see that. That's interesting. It seems that it's not uncommon for it to leak even so, however.
  9. The Critic
    3,193
    2,333
    CA
    The old ones leaked quite regularly, I have changed a number of them.
    The metal ones rarely leak. Not saying it does not happen, but it is rare. The tensioner is in such close proximity to the timing cover seal that any oil seepage from the timing cover can be confused with a tensioner gasket leak.
  10. oldtechaa
    336
    225
    NZ
    2013 Prius Alpha
    OK, I'll have to do a bit more digging. I do have 2 much closer angles here, though.
    I'll try cleaning the area and see if I can see exactly where it comes from. Thanks for your help.
  11. Mendel Leisk
    41,865
    Gasket might even be missing??
  12. The Critic
    3,193
    2,333
    CA
    To me it appears to be seeping from where the block, cyl head and timing cover intersect. There is a larger seem there that requires a bit more rtv to seal.
    But since it is dirty, hard to say.
  13. Mendel Leisk
    41,865
    OP's clean up an monitor will hopefully clarify.
    Is it a big deal to remove the timing chain tensioner and replace the gasket? Would you need to crank the engine counterclockwise a bit to release it?
  14. Mendel Leisk
    41,865
    Timing chain tensioner install info:
  15. oldtechaa
    336
    225
    NZ
    2013 Prius Alpha
    I was thinking about just replacing the tensioner gasket since it's cheap and easy, but that looks a little more difficult than I thought. Does the timing cover have to be removed? That's kind of how it looks, but in the video I saw it wasn't necessary. I'll clean and run first, probably tomorrow, then report my observations. Here's one more picture showing the connector that was dripping and everything from there up to the tensioner. Thanks for your help and the repair manual pages.
  16. The Critic
    3,193
    2,333
    CA
    Tensioner comes out fairly easily - just two bolts. Best practice is to put the engine at cyl 1 TDC to make sure it does not jump time, but most people skip this step.
    The oil pressure switch can sometimes drip. That is probably a more likely leak point than the tensioner. The switch comes off with an adjustable wrench. I usually use thread sealant on them but I think Toyota specs something else.
  17. ASRDogman
    ASRDogman Senior Member
    7,793
    3,976
    Oil pressure switches usually leak where the metal is crimped over the plastic because of the
    heat/cold cycle and the plastic get hard and cracks. If you pull the rubber cover off of it, it's probably full of oil.
    Best to gunk it down(cold engine), how it off, blow dry it if you have a compressor.
    If not, try to dry it with a rag, or let it sit with the hood open to dry, then drive it a few miles to warm it up.
    Then check everything.
  18. oldtechaa
    336
    225
    NZ
    2013 Prius Alpha
    You're all correct. It is the oil pressure switch. I have a new one coming from RockAuto. The dark area around the head gasket and tensioner must just be seepage over time, but the oil pressure switch was clearly leaking out the connector. Thanks for your help. I'll leave an update if I have any problems.
    ASRDogman and Mendel Leisk like this.
  19. ASRDogman
    7,793
    3,976
    You're welcome. I've seen a lot of those leaking. Oil goes EVERYWHERE!
    The one on my Town and Country leaked a lot. I was really amazed at just how much
    oil can leak out of that thing!
    Just gunk it down good after you change it. And clean out the rubber boot cover and connector.
    You could still have another leak, but the pressure switch was probably the worse leak. And you may be
    able to live with a different leak. I've used silicone, and rubbed it over seeping leaks to stop them.
    For a while anyway... :)
  20. Mendel Leisk
    41,865
    Info on oil pressure sensor:
