What type of mpg should I expect from my gen 2?
Discussion in 'Gen 2 Prius Fuel Economy' started by Banksy, Apr 10, 2020.
Tags:
  1. Banksy
    Banksy Active Member
    415
    132
    Lancaster Pennsylvania
    I just put a HV battery in my 2008 Prius.
    I haven't driven this car since I've had it due to having to put said battery in it lol
    What is a realistic mpg for this car?
    I notice that on the readout for current mpg when you're driving it dips a lot when you're going up a hill or just in general have your foot in the gas (which makes sense...)
    What should I expect with regular rural and highway driving for mpg?
    52,349
    40-50 mpg based on weather, driving style, speed, accelleration and hills and dales.
    05PreeUs and kenoarto like this.
  3. dolj
    dolj Senior Member
    8,549
    4,341
    Wellington, New Zealand
    It really depends on a lot of things, including whether the HV battery you put in was a new one or second-hand.
    You could expect anywhere from 39 - 49 MPG. The US average on Fuelly is ~44 MPG. Some in the US do get up to 50 – 52 MPG, but these seem to be the outliers.
    srellim234 and kenoarto like this.
  4. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    In my experience, a gen2 that is had it’s maintenance done properly, driven in normal conditions, mix city highway, should average around 44-46. We’ve had a new gen2s in the family, and friends with them as well.
  5. Banksy
    415
    132
    Before my old HV battery died I was averaging like 46-47
    I have also replaced the air filter and have some new tires on in the front.
    Considering doing the spark plugs too
  6. bisco
    52,349
    how many miles on her? you should consider following the maintenance schedule
  7. Banksy
    415
    132
    250k
    I also just cleaned the throttle body
    Which was WOW kinda dirty.
  8. Lord Claverton
    Lord Claverton Junior Member
    Bath, UK
    Average 55mpg (UK) 235k 2007, but has been serviced every 6 months from new
  9. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Being snarky....
    The further up the evolutionary chain, the higher the mileage ;)
    If you drive like an absolute animal, 40ish, if you drive like a reasonable, conservative person who values their life and that of others, up to about 50 MPG.
    Data Daedalus and Banksy like this.
  10. Banksy
    415
    132
    Yeeeehawwww
    I baby it like it's a vehicle with a quarter million miles on it
    Oh wait.. it is a vehicle with a quarter million miles on it.
    Data Daedalus and bisco like this.
  11. Bob-W8RH
    Bob-W8RH Junior Member
    Maricopa Arizona
    My wife's 2008 is a new traction battery and I got 50 miles per gallon on the last three hundred miles mostly highway driving, my 2007 touring with 241 thousand Miles gets 45 miles per gallon. It has the original battery.
    Data Daedalus likes this.
  12. lpf
    lpf Member
    139
    39
    Greece
    One year old replacement battery gives me 750-780 km in the city, means 44-45MPG. Weather and temperature does not affect consumption until now.
  13. Mendel Leisk
    41,859
    Yeah but winters in Greece? That said, we've watched a few Turkish series (just next door), and (especially in Ankara) they're freezing their butts in winter, snow and everything.
  14. lpf
    lpf Member
    139
    39
    Greece
    I'll report next winter, I have the car for 4 months only. Winter in Athens rarely gets below 5 Celsius, not to compare with Ankara!
    Mendel Leisk and dolj like this.
  15. lexidium
    lexidium Active Member
    301
    143
    manchester
    My 2008 gets about 60 average if I drive carefully. That's about 50 in US
    Data Daedalus and Mendel Leisk like this.
  16. Mendel Leisk
    41,859
  17. flypriguy
    flypriguy Member
    Atlanta
    I USED to get around 45mpg in my old Gen 2's, but that was with commuting to work. In my current one I'm getting about 37ish. I believe the battery is ok rather it's because I do a lot of really short trips in a hilly area. If I take the car on a long ride, it slowly creeps up again into the 40's.
    kenoarto and Bobbytwotaps like this.
  18. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Does it go to purple bar at the light or drive through?
  19. Brando714
    Brando714 Member
    101
    Anaheim, CA
    I have an 04 Prius and bought it used at 175K. Been driving it for about 1000 miles now and my average is about 41MPG. My hybrid battery test shows that battery capacity is estimated at 58% provided via Dr. Hybrid app. I've cleaned the MAF sensor, throttle body cover, replaced engine filter, make sured air is set at proper PSI and don't drive on the freeway with windows down. All these plus more can be a factor to lowering or increasing MPG
    kenoarto likes this.
  20. Banksy
    415
    132
    I have about 3k on this car after replacing the pack
    Currently averaging 47 but have gotten over 50 on two tanks
    That ac kills the mpg
