Can I buy a new hood latch trigger spring or do I need a whole new hood latch?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Banksy, Apr 11, 2020.
Tags:
  1. Banksy
    Banksy Active Member
    415
    133
    Lancaster Pennsylvania
    The hood on my gen two wouldn't close properly
    After taking it apart I noticed the larger spring inside of the latch had rusted and broke
    I've seen entire latch assemblies on Amazon for like 20 bucks. However I just need the spring and it'll work
    I can't find one specific to a gen 2 Prius on eBay or Amazon... So it's making me wonder if maybe they all use similar ones?
    If someone could direct me where to look I'd appreciate it.
  2. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    Look here to find the original part numbers: TOYOTA PRIUSNHW20L-AHEEBW - BODY - HOOD LOCK HINGE | Japan Parts EU
    As they exist, there also should be the separate springs to buy.
    If you don't find them to buy anywhere and have to improvise, I would say, that WD is the wire diameter in mm and CW maybe the number if windings. Similar springs should show a similar characteristic. Screenshot_20200412-043316_Firefox.jpg Screenshot_20200412-043604_Firefox.jpg
    SM-G950F ?
    UggaDugga and Elektroingenieur like this.
