Plastic shavings on oil dipstick
Discussion in 'Gen 3 Prius Main Forum' started by Apatel1101, Mar 12, 2020.
  1. ASRDogman
    ASRDogman Senior Member
    5,897
    3,161
    Then you can test the water pump with techstream...
    I don't know if you can check the oil pump also, if you can, great!
    Uphill noise? MMM I dare say possibly a bearing in the transmission. Hard to diagnose through here....
    But possibly another head shield with help of the light angle. I would check all you can reach.
    Things like that are a royal pain to find!
  2. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    i checked all the exhaust shields more than 4 times and the noise coming from passenger side so i doubt that its transmission bearing. I am going to try to record the noise tomorrow with my gopro
  3. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
  4. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    I have uploaded the audio file on the drive. it mainly comes from the passenger side. Noise only comes when i am driving and sometime comes if its on ramp in my garage.
  5. BZzap!
    BZzap! Senior Member
    1,607
    877
    Sounds just like a bad A/C compressor. When you downloaded this sound clip, at what mode was the HVAC set?
  6. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    everything was off.
  7. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
  8. ASRDogman
    5,897
    3,161
    Sounds the shield around the exhaust. Or maybe the exhaust weld broke inside the pipe.
    Maybe give it a smack with the hammer... :)
    PriusGuy32, Apatel1101 and Ragingfit like this.
  9. BZzap!
    1,607
    877
    According to that video, the catalytic converter has a broken internal baffle.
    PriusGuy32, Apatel1101 and ASRDogman like this.
  10. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    wouldnt that cause engine light to be illuminated. I found the catalytic converter shield has one mount that is rusted out. I bought some clamps so i ll work on it tomorrow and see if it solves it.
    its the exhaust shield. Will know tomorrow if it is that tho
    Mendel Leisk and ASRDogman like this.
  11. BZzap!
    1,607
    877
    This is my post from 4/16/20
    ASRDogman likes this.
  12. Mendel Leisk
    38,213
    Just editorial, April 16th, 2020? That's in the future. ;)
    Raytheeagle likes this.
  13. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    His post was from March 16th;).
    But there is a difference in a 3 versus 4(y).
  14. BZzap!
    1,607
    877
    I stand corrected! Gimmi a break! I’m retired and easily lose track of time and space.
    BTW, Happy Easter...I think.
  15. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    276
    Redwood City, California
    Just post it again 3 days from now and you'll be all good.
    BZzap! and nssdiver like this.
