Charging/discharging HV battery out of the car.
Discussion in 'Gen 2 Prius Technical Discussion' started by Siber Pir8, Apr 13, 2020.
  1. Siber Pir8
    Siber Pir8 Junior Member
    55
    UK
    Hi all,
    Is it possible/will I damage the HV battery using the prolong charger/discharger on the HV battery out of the car? Here in the uk temperatures are pretty low especially in the evening which is when I will most likely due it in a shed.
    As it's not feasible trailing 2 extension leads from my house to my parking spot.
    Thanks.
    52,356
    i don't think so, check with hybrid automotive
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    You can discharge out of the car;).
    Just more work to lift and carry the pack I would say:cool:.
    But @SFO has done what you have suggested successfully:).
    And the battery rebuilders who care about quality do it all the time(y).
    SFO and edthefox5 like this.
  4. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    I would rig up the fan and duct if you do it out of the car. It will build a lot of heat even if the temp is low.
    Raytheeagle, strawbrad and edthefox5 like this.
  5. Albert Barbuto
    Albert Barbuto Active Member
    113
    104
    Northeast USA
    If the metal cover is removed over the entire pack, heat buildup at 350ma is minimal. So no fan required. With the metal cover in place, fan is needed as a surprising amount of heat is trapped. If you want to be anal, any fan lying atop middle of modules blowing up, will keep entire pack nice and cool. Cool night temps are a bonus...
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Whatever you do, do not unbolt the packs. Many a poster has cracked some cells charging them unbolted. When not squeezed together they will expand greatly causing a huge void in your wallet.
    R-P, 05PreeUs and Raytheeagle like this.
  7. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Hey Todd whats the latest price on G3 cells in a G2?
    Cash.
  8. Siber Pir8
    55
    UK
    Cool, thanks for the advise guys! I will take it on board.
    Has anyone thought up any cooling solutions for the pack? Eg drilling any large holes in the cover to allow air to escape quicker?
  9. dolj
    dolj Senior Member
    8,550
    4,343
    Wellington, New Zealand
    That wouldn't be a good idea. A better idea would be working out a way to get air through the battery.
    The member mention above in post #3, got the fan and ducting from a wrecked/dismantled car and has that set up on his bench. He connects the ducting to the battery on the bench and then powers the fan to draw air through the battery while it is charged. You might think about "MacGyver-ing" (if you are familiar with that old TV series) something makeshift to do the same.
    edthefox5 likes this.
  10. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Yes, spoofing the battery fan to run either all the time or at higher speeds is being done.
  11. edthefox5
    10,096
    4,834
    Clearwater, Florida
    No that would be like drilling holes in your home ac handler box.
    The battery is counting on pulling cooler air from the cabin using the battery fan through the air tight battery box and pump it out the rube goldberg vent connection by the 12 volt battery. The fan is controlled by PWM for variable fan speed.
    Want to make the battery cooler? Keep the cabin cooler.Don't drive around with the windows down sucking in hot moist air. battery likes dry & cool.
    Besides using the ac everyday makes it last for years.
    One member has a way using techstream to speed up the fan during normal use increasing air speed.
    #11 edthefox5, Apr 14, 2020
