Transmission fluid check
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Harry Le, Apr 13, 2020.
  1. Harry Le
    Harry Le New Member
    2017 Prius c
    Hello,
    My car is 2017 Prius C. I am looking for the transmission fluid rule where I can check the level of fluid, but I did not see it. Can anyone here could let me know where is it?
    Thanks
  2. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    It doesn’t have one. The correct fluid level is when it’s just about dripping out from the fill hole. The car should be perfectly level. It can only be accessed from below the car.
  3. bisco
    52,069
    instead of checking it, just change it
  4. Harry Le
    Harry Le New Member
    2017 Prius c
    Base on this video from Weber State University, for Prius C with normal driving, I think we no need to change the transmission fluid. I saw some people in here changes transmission fluid at just around 30,000 miles for Prius C, I think that is totally wrong.
  5. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    You definitely should change the transmission fluid. This is not a normal automatic transmission. It’s only metal gears grinding against each other like manual transmissions and differentials. People drain and fill those units regularly. The lubricating properties of gear oil degrade over time. It’s up to you but it’s better to be safe than sorry.
    Harry Le, edthefox5 and Mendel Leisk like this.
  6. Mendel Leisk
    41,628
    Once you've verified level is correct, say by doing a drain and fill with car level, I wouldn't bother with further checks, as long as there's no leaks.
    Harry Le and iceman13 like this.
  7. Harry Le
    Harry Le New Member
    2017 Prius c
    Yes, I think we just make sure there is no leaks only. If no leaks, no worry anymore
  8. bisco
    52,069
    what's in the video? did they send it out for an oil analysis?
  9. bisco
    52,069
    just startng to watch it, that isn't a prius ecvt. nothing in that video corresponds to prius, ignore it.
    Harry Le likes this.
  10. bisco
    52,069
    just remove the fill plug and stick your pinky in there. if there's oil, you're good to go.
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    You didn't say your mileage but if more than 30,000 miles you will greatly enhance the trans life by changing that fluid as it has all the bad break in stuff. Once changed never have to do it again.
    iceman13 likes this.
  12. Harry Le
    Harry Le New Member
    2017 Prius c
    @bisco: that guy talking about “sealed transmission”- that is Prius C, right?
    @edthefox5: If you change the fluid at 30,000 miles , why never do it again? The fluid is not dirty anymore after 30,000 miles changed? It is not make sense.
  13. bisco
    52,069
    not sure what you mean by sealed. the c has a drain plug and a fill plug. he's talking about conventional toyota automatic transmission. c has an 'ecvt' electronic continuously variable transmission.
    there's no drain and tube combo like he was showing.
  14. Harry Le
    Harry Le New Member
    2017 Prius c
    @bisco: I think the “sealed” word is a little bit confusing. It is not like sealed not come in not come out. “Sealed” means it has no dipstick, can’t check the level of fluid, so they don’t want the users, or technicians touch if it has no any signs like leaking, noise...I attached that video for example of my original question because my car has no dipstick too. They call that is “sealed transmission”.
  15. Harry Le
    Harry Le New Member
    2017 Prius c
    @bisco: I think the “sealed” world is a little bit confusing. It is not like sealed not come in not come out. “Sealed” means it has no pipstick, can’t check the level of fluid, so they don’t want the users, or technicians touch if it has no any signs like leaking, noise...I attached that video for example of my original question because my car has no pipstick too. They call that is “sealed transmission”.
  16. bisco
    52,069
    fair enough. i'm just saying you can check the level easily enough (not as easy as a dipstick of course) and you can also fairly easily do a drain and fill, or you can have someone else do it for around a hundred bucks.
    the reason some do it at 30k is to get out all the break-in material that wore off the new gears and is circulating through the oil.
    but not everyone agrees how early or how often, since there is no guidance from toyota.
    on the whole, if you're not keeping the car more than 150k, you don't need to change it at all, because there are very few failures within that mileage.
    it's more of a 'best practices' thing
    Harry Le and Mendel Leisk like this.
  17. Xaver Pinero
    Xaver Pinero New Member
    Chattanooga, Tennessee
    So based off this comment, if I have a small transmission leak (from a rubber hose it appears) and I need to fill it up before a long trip (I know I need to fix the leak asap, but need to leave for this trip first), all I need to do is warm it up, raise it level and pump fluid in until it pours out? I would really appreciate a input. Edit: I have a 2016 Prius 2.
  18. Mendel Leisk
    41,628
    I don't think it needs to be warmed up.
  19. dubit
    dubit Senior Member
    850
    538
    Indiana
    2016 Prius c
    If you want to give it a check, follow the thread I'll link to below, Changing the fluid is no harder than changing the oil. I recommend however being able to lift the vehicle if you can. That being said, in the thread I link to below, you didn't seem to be interested in changing the fluid. If your going to go through checking it, you may as well change it. You'll already be there and it takes 10 minutes.
    How to: Change Transmission Fluid ATF WS | PriusChat
    See my reply in post number 20 of that thread - I still recommend buying that as it makes the job much easier
