Towing... 4 to 7 pin w/brake controller for electric brakes?
Discussion in 'Gen 2 Prius Main Forum' started by jerlands, Apr 17, 2020.
  1. jerlands
    jerlands Member
    173
    Pioneer, Ca
    i'm considering a small trailer build (around 300 lbs. empty - 1500 lbs. max) and want electric brakes... the car currently has a 4 pin setup... it seems i need to run 4 additional wires and i'm looking for a good path to where the brake controller will be mounted (unknown at this point.).
    1.) +12v directly to battery (w/circuit breaker),
    2.) ground,
    3.) a wire to the controller
    4.) a sensing wire for the brakes....
    i'm questioning if it's a good idea considering the prius electronics and all...
    Has anyone done or heard about doing this on the prius?
    all suggestions welcome...
  2. Leadfoot J. McCoalroller
    8,172
    7,679
    Pennsylvania
    2018 Prius c
    I'm only replying because I think you're likely to get few replies. The particulars of my experience might not be a good match.
    I installed a Tekonsha 4-wire kit on my Prius c. The kit was labeled for a c, but in fact was meant for the regular Prius. Everything was the wrong length for my car and I wound up having to hack it up and rebuild it as the manufacturer was utterly clueless- and that's sad, because Tekonsha is a leading name in tow equipment.
    Anyway, their kit would fit a regular Prius like yours for a 4-wire application, and they do it properly with transformer isolation on all the lines and an independent controller.
    In my case I had no trouble installing the actual control module in the same general area as the 12v battery in the back of the car, and it works perfectly. Obviously for a 7-wire setup, you'll also need to run wires forward to the dashboard for the override controller/accelerometer module; I can't tell you what you'd be up for there.
  3. jerlands
    jerlands Member
    173
    Pioneer, Ca
    the 4 wire is already installed... all i have to do is the adaption... i need to place the controller near the driver because there is a manual override i'd like to have (sierra/rockies.) i figure i can find my way forward with the wiring but i am concerned about the load it might place on the 12v system...
  4. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    I do not get ANY consideration from them, but the folks @ e-trailer*com would likely be a good resource.
  5. jerlands
    jerlands Member
    173
    Pioneer, Ca
    i plan on ordering an axle from them (for the trailer build) so i'll discuss it at that time. i did read something from their answer box, when asked about a prius, and the guy seemed to think you could stick one in just about any vehicle. although he did qualify that by saying "call the dealer and ask about it" and i think i already know that answer...
  6. Leadfoot J. McCoalroller
    8,172
    7,679
    Pennsylvania
    2018 Prius c
    I'd be a lot more worried about a 14 year old radiator, assuming this project is meant for the 2006 Prius listed in your profile.
    Trailer brakes & controller are well within the capability of a healthy Prius 12v battery.
  7. jerlands
    jerlands Member
    173
    Pioneer, Ca
    well... this car has given me some challenges but i've come to enjoy it... but... there does come a time :)
    i can always remove whatever controller i install so i don't see that as a problem but traveling any distance on a vehicle with 150k has it's inherent risks...
    new traction battery
    new 12v battery
    new struts
    new inverter water pump
    new steering wheel spring pack
    new up and down O2 sensors
    new purge valve
    and some other stuff... the thing uses about a quart/1k mi... so a rebuild is probably about 10k away...
    #7 jerlands, Apr 18, 2020
  8. Leadfoot J. McCoalroller
    8,172
    7,679
    Pennsylvania
    2018 Prius c
    Well, I've towed with old cars too. It can be done, but a little planning and awareness now goes a long way when you're in the moment with a loaded trailer.
    Radiator performance is a real thing- it may have the extra buffer needed for towing duty when new, but after x years the mineral deposits build up and there just isn't as much heat transfer anymore. I'm led to believe that in a Prius, the early symptom is the air conditioner cutting out- the computer is predicting an overheat and turning off non-essential loads to preserve cooling ability. It doesn't warn you about this anywhere, it just does it.
    So if you tow with an older Prius, look out for that. You'll want to make sure your tires & brakes (especially fluid) are on the young side; that goes for any tow rig.
  9. jerlands
    jerlands Member
    173
    Pioneer, Ca
    i will have to keep an eye on the cooling side of things.. that issue with the AC kicking out due to a clogged radiator may be a factor in an issue i had earlier with it...i have techstream and can do a little testing before long distances... and i'm just around the corner on new pads...so... it is going to be an experiment :)
  10. jerlands
    jerlands Member
    173
    Pioneer, Ca
    i may have to learn how to tig so i can do the frame in aluminum. so your comment now has now has me relooking my design cutting everything off the trailer i possibly can... no spare tire for it...
  11. Leadfoot J. McCoalroller
    8,172
    7,679
    Pennsylvania
    2018 Prius c
    Well that's one way to do it! I'd imagine a new radiator is south of $200 though, if that factors against welding school.
  12. jerlands
    jerlands Member
    173
    Pioneer, Ca
    i wasn't planning on going to school but you're persuading me into the radiator... and hoses...
  13. dolj
    dolj Senior Member
    8,604
    4,366
    Wellington, New Zealand
    I've never heard of radiators being the problem attributed to this. The issue you speak of is related to inverter coolant pumps (ICPs) becoming less efficient over time and so pump less and less coolant until they finally fail and circulate no coolant. The car can still function under a light workload, but as the workload increases and the inverter gets hotter it will throw a DTC (diagnostic trouble code) P0A93. When this happens the system does indeed shut down things to lighten the load, starting with shutting off the A/C compressor. Replacing the ICP is a quick and (relatively) easy job to DIY. OEM pump and some coolant. Some aftermarket ICPs have been documented failing early and/or working intermittently. It makes sense not to penny-pinch with this as a new OEM will go 100,000 mi before you will need to do it again.
    Instances of clogging seem to be credited to adding stop leak products or mixing different brands of coolant, from cases I've seen.
    #13 dolj, Apr 19, 2020
  14. frodoz737
    frodoz737 Top Wrench
    4,734
    2,526
    33
    Having towed many times with GEN III (2010 and 2015) I would like to offer opinion. Based on having the 1.5L engine, the age of your vehicle and your planned tongue, empty and load...trailer brakes are over kill. If you really do need them...then you are towing way over anything considered close to safe...in the real world. That said, many hear believe and told me not to tow class 1, but I still did/do, but never exceeding mid class 2. Best wishes what ever you do. As already implied...you vehicle must be serviced fresh on a severe duty cycle and in excellent mechanical condition.
    #14 frodoz737, Apr 19, 2020
  15. Leadfoot J. McCoalroller
    8,172
    7,679
    Pennsylvania
    2018 Prius c
    Thanks for the amplification/clarification. The only Prius I've towed with is my own, and it is too young to have these problems.
  16. jerlands
    jerlands Member
    173
    Pioneer, Ca
    that's for that... the trailer i'm putting together should be under about 350 lbs and i doubt i'll be putting more than 450 lbs on it... essentially it's a 3' X 4' box that's 2 ft. high... so if i don't need the brakes i could well do without the headache of their install... mind you.. i am intending on crossing the rockies :)
  17. Leadfoot J. McCoalroller
    8,172
    7,679
    Pennsylvania
    2018 Prius c
    With those additional details? Yeah, I wouldn't bother with trailer brakes either. But please make sure your tires and brake fluid are new-ish, and you'll want to check all of the cooling systems, including the battery cooler fan.
  18. frodoz737
    4,734
    2,526
    33
    Additionally understand...your mpg WILL take a hit. ;)
  19. jerlands
    jerlands Member
    173
    Pioneer, Ca
    those are real good considerations cowboy...
  20. 05PreeUs
    1,097
    565
    MSP
    Because the Inverter runs the AC compressor! It will also reduce DC-DC power to relieve the thermal load on the HSD cooling system.
    Overheating the ICE is a completely possible, although abnormal result of towing. Overheating the HSD system, on the other hand, is extremely unlikely barring an underlying condition.
    Yea, no reason AT ALL to put any stop-leak or other non Toyota approved fluid in the HSD cooling system.
