Opinion-like-new Prius brake pads at 100k miles:
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Apr 17, 2020.
  1. ski.dive
    ski.dive Active Member
    967
    247
    Hutchinson Island,FL. Mt. Snow,VT
    Is 100k+ miles on the Prius brake pads normal???
    I found these photos of Wayne Brown Prius photos of his like-new brake pads at 100k miles:
    How many miles on your brake pads?
    #1 ski.dive, Apr 17, 2020
    52,804
    yes
    SFO likes this.
  3. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    depending on how you drive and brake, absolutely.
    I read about it all the time on PC
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Shoot! I was getting close to that on conventional cars. :D
    My wife's 1st Prius had the original pads when it got totaled at 175,000 miles. Mine had the originals when I traded it at 150k. Wife's current Gen 2 has 138,000 miles and 6mm of brake pad left.
    edthefox5 likes this.
  5. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    I'm expecting 150-200k miles on mine.
    I do all my own work, but the PO went to the dealer every 5k miles, where they measured the pads each time. From the receipts, several times, the thickness actually increased over the span of 5k miles. So maybe they're like fingernails and actually grow when not used much. :whistle:
    Montgomery and jerrymildred like this.
  6. Leadfoot J. McCoalroller
    8,278
    7,782
    Pennsylvania
    2018 Prius c
    Pretty ordinary result. Now make sure your brake fluid is fresh- a 2008 ought to be on its 2nd flush by now, I reckon.
    Montgomery likes this.
  7. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    With salted roads rotor actually seems to wear faster than pads. Even with super coarse rotor surface the pads had lots of material left at about 220tkm or 140t miles at 12 years but rotor was bellow the allowed thickness so they would need to be changed. This is actually pretty common in hybrid cars and probably electric cars too.
  8. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    230k+, never had a "brake job", but I did lubricate the caliper slides a few years back.
    Montgomery and edthefox5 like this.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    155000 on my bought new 07 haven't touched the brakes stops fine rotors look perfect and pads ok.
  10. bisco
    52,804
    68,000 miles and 8 years, never looked at the brakes, never mind touch them. i suppose it will come back to bite me someday...
    #10 bisco, Apr 18, 2020
  11. ChapmanF
    18,980
    My record of measurements every tire-rotation interval also occasionally looks like 'growth' of a pad or a rotor.
    Nothing is 'growing', but I'm measuring with instruments that give four significant digits, at intervals where I don't always remember exactly what spot on the pad I measured last time, and the temperature may be different, and the length of time the tool stays in my warm hand may be different. At least I have a certain technique that I try to be consistent with; the variation would be even more if different people were making the different measurements.
    ... why measurements in scientific work are always given with error bars ....
  12. 2012 Prius v wagon 3
    281
    278
    Yes, I know. Of course. But if the rate of change is so slow, there is no need to measure them at 5k mile intervals, which was the point of my joke. Dealer tricks to make you think they're doing something useful. They're doing something, but it is a waste of your money.
  13. ChapmanF
    18,980
    It is a bit like checking the dipstick. There is no reason to check that every fillup, until there is. Then it is good to have caught it.
    With the brakes, if something has seized or a foreign object been caught since the last time you checked, it will make a kink in your pad-life/miles graph and lead to an alteration in your projected pad replacement time.
    But not as much of an alteration as it would if you never noticed.
  14. valde3
    2,002
    750
    Finland
    Yes.
    Although perhaps just pushing or levering the caliper out while just visually check the pads might just as good or even better. You would move everything that could get seized. That way you would know if they were starting to get seized and you would also reduce the change of them getting seized in the future.
  15. ChapmanF
    18,980
    One thing that steadily happens, and has always begun happening on my car by the time I rotate tires and inspect brakes, is that the slide pin grease begins to take a set. That doesn't mean it has gone bad or the pins are rusted or anything like that; grease that hasn't moved much over a period of time just starts to get like peanut butter. It happens in this case because the caliper barely moves a quarter millimeter one way or the other when you normally apply the brakes.
    The peanutbutteriness goes right away with a few quick in-n-outs with the pins (just as far as the rubber boots extend, no need to remove them or do anything more involved). You might have to put your thumbs behind it the first time, but then you'll feel it slipping in and out just like a nice well-greased pin should.
    That's a lot easier to do if you just go ahead and loosen the two bolts (one all the way out) and flip the caliper up so you can shove it back and forth. You can't do that same back-and-forth with the caliper in position unless you're going to apply enough force to shove back the piston, which brings other considerations of its own.
    That minute of flipping the caliper up also allows you to get an easy look at the shape of the pads in profile, the conditions of all the rubber boots and the fitting kits, and so on.
    So far the parts I most commonly discover ready for replacement are the fitting kit clips; they'll reach that stage every couple, three years, it seems, in my climate, anyway.
  16. cthindi
    cthindi Member
    177
    85
    Connecticut
    I got 264 K on my brakes. There was no noise and brakes were working fine as well. But then my wheel mounting stud broke. So I had to take a rear wheel and brake drum out. The pad was at low end of tolerance and there was a groove in drum. I had all drums, rotors, shoes, pads replaced. All were near low end / below limits.
    Savings on brakes alone justify the hybrid premium.
  17. 05PreeUs
    1,097
    565
    MSP
    That did not "just happen"... Some gorilla improperly torqued that wheel nut.
    Considering a single brake job can be $500+, but wait, a premium for a Hybrid? They are generally cheaper than a similarly equipped Corolla or certainly Camry.
  18. cthindi
    cthindi Member
    177
    85
    Connecticut
    There is definitely some premium. I do not know whether to compare Prius to a Camry or Corolla. Prius has cabin space similar to Corolla with more legroom but it can carry even more stuff than Camry.
    However if you compare apples to apples, Rav4 Hybrid Vs equivalent Rav4 or Camry hybrid to Camry, or Highlander for that matter, Hybrids are definitely more expensive when purchasing. The difference in most cases between 800 - 2000 $.
    IMO Toyota has certainly attempted to price hybrids attractively. But then at times it can affect negotiating room for hybrids. Gen 5 Rav4H as an example.
    What I meant is that initial price difference, that I termed 'Hybrid Premium' is certainly offset by savings on brakes alone over the life of the vehicle.
    #18 cthindi, Apr 19, 2020
  19. 05PreeUs
    1,097
    565
    MSP
    See there, since I happen to OWN a RAV4 Hybrid, I can tell you that it was CHEAPER than the "equivalently equipped" non-hybrid.
    Again, there is no hybrid premium, that assertion is vaporware. Now, dealer A vs B on a similar model can vary $2500++++/----. When you equip a non-hybrid to the same as, or very similar features as the hybrid, they are almost always less expensive, but admittedly not by much!
  20. Graeme1949
    Graeme1949 Member
    51
    47
    Atlanta, GA
    Yes, I would say that's about normal. My 2004 got new brake pads at about 120,000 IIRC. We're now over 190 k but she has been relegated to twice-a-week short trips.
    I remember the old days (BT - Before Toyota) when brake pads & shoes were an annual or even semiannual thing. And they contained asbestos.
    -Graeme-
    2004 Prius with >190,000 miles.
    Sent ?.
