my prius have problem with P085d -582
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sovannaroeun, Apr 17, 2020.
  1. sovannaroeun
    sovannaroeun Junior Member
    Can you help me
    iPhone ?
    51,249
    gear shift control module 'a' performance
    causes:
    1) wiring harness connector loose or corroded
    2) bad transmission control ecu assembly or corroded pin out
    3) bad hybrid vehicle control ecu or loose/ corroded pin out
    4) bad power management control ecu or loose /corroded pin out
  3. sovannaroeun
    wow bad a lot sir
    iPhone ?
  4. bisco
    51,249
    yes, these are very complicated cars. computers on wheels, basically
