Cylinder Bore/Length/Volume? Air/Fuel Ratio?
Discussion in 'Prime Technical Discussion' started by Gearoid McDonald, Apr 20, 2020.
Tags:
  1. Gearoid McDonald
    Gearoid McDonald New Member
    Ireland
    2019 Prius
    I am not actually a Prius owner but I am a mechanical engineering student currently doing a project on analyzing the drive train configuration for a prius (any model). I would very much appreciate if anyone would happen to know the cylinder dimensions of the engine? and any typical air/fuel ratio
    Thanks!!!
  2. schja01
    schja01 Senior Member
    1,862
    1,234
    Chicagoland
    2024 Prius
    Limited AWD-e
    Remember the Prius is Atkinson Cycle not Otto.
    I believe this delays the closing of the intake valve to reduce the volume of fuel/air during the combustion cycle. This may come into play for some of your calculations. Or not.
    J
  3. ChapmanF
    18,874
    Toyota's Technical Information Service is described in detail here.
    For a small subscription fee, you get access to the entire technical library. In particular, there is a volume there called the "New Car Features Manual" (the NCF tab, online) that contains all the specifications you are looking for. They may be repeated in the Repair Manual (the RM tab).
    In addition, that library has "Quick Technical Guides" on a variety of topics, technical service bulletins, special service and warranty campaigns, and (under a separate Technical Library tab at the top) course materials used in "University of Toyota" technician training courses.
    You might find a lot of that, beyond just the bore and stroke numbers, useful in your project.
    Elektroingenieur likes this.
  4. Elektroingenieur
    2,515
    3,288
    Three Touring
    The cylinder bore and stroke of the two main engine families used in Prius cars are, for the 1NZ-FXE (2001–2009 and Prius c ), 75.0 mm × 84.7 mm, and for the 2ZR-FXE (2010–present), 80.5 mm × 88.3 mm.
    As @ChapmanF kindly mentioned, the New Car Features book is a good source, and the other materials on Toyota’s TIS make it well worth the modest cost. In particular, see the Engines chapter of the Technician Handbook for the Hybrid Systems (T071) course, and the Advanced Emissions and Drivability Diagnosis (T972) course, which has a good explanation of air/fuel ratio and its effects on emissions.
    I’ve previously suggested some books on hybrid vehicles; in particular, the Hayes and Goodarzi book takes a much more quantitative approach than you’d find in materials prepared for technicians, and they may have already worked out some of whatever you’re analyzing. @bwilson4web kindly reviewed some SAE technical papers from authors at Toyota; there were similar papers about the engines and drivetrains of earlier Prius cars. Oak Ridge National Laboratory did teardowns of the hybrid systems in the 2004 and 2010 models.
    If your focus is the engine itself, see Garrett’s The Motor Vehicle, Bosch’s Gasoline Engine Management: Systems and Components (or the standard Bosch Automotive Handbook ); SAE’s Internal Combustion Engine Handbook; and Hoag and Dondlinger’s Vehicular Engine Design.
    Mendel Leisk and schja01 like this.
  5. Gearoid McDonald
    Ireland
    2019 Prius
    Yes I have the Atkinson cycle characteristics modeled, the last piece is just the air/fuel ratio but thank you!
  6. Gearoid McDonald
    Ireland
    2019 Prius
    Awesome I'll check that out now thank you!
  7. Gearoid McDonald
    Ireland
    2019 Prius
    Awesome, some good sources I can definitely reference in here, thanks!
  8. Bill Norton
    Bill Norton Senior Member
    2,230
    746
    MONW, Ks.
    2019 Prius
    L Eco
    Pseudo Atkinson Cycle.
    Yes it does tricky stuff by varying the intake valve.
    That is why it can burn regular gas, but it has a High Compression Ratio, on paper.
    I've always wondered if it does not lose power with altitude, to a point, compared to a normal engine.
    Does it maintain an effective compression ratio as the altitude increases?
  9. ChapmanF
    18,874
    I think it has a high expansion ratio, in contrast to a low compression ratio. It would be Otto cycle if they were the same.
    I'm not sure you need anything beyond a low compression and high expansion ratio to be a bona fide Atkinson cycle engine. Atkinson's original design accomplished that by a different mechanical arrangement, but I'm not sure that's the part that matters.
    Bill Norton likes this.
