2008 Gen 2 tyres question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lpf, Apr 28, 2020.
  1. lpf
    lpf Member
    113
    33
    Greece
    A post mainly for European owners:
    I recently got a Gen 2 Prius from France that needs tyre replacement. I see that the tyres are 195/65 R16 and I believe that this is not correct as most cars with the magnesium 16" wheels are fitted with 195/55 R16 (picture). What is the correct factory size? What happens if I get back to 195/55 regarding MPG and speedometer indication? Speedometer now reads 100km/h for a real 94 km/h. Also the car will be lowered and I don't know what will change regarding the softness of the suspension. Thanks
  2. MickyMatter
    MickyMatter Active Member
    260
    166
    Germany
    195/55R16 is correct. That's the only dimension I'm allowed to drive with my 2008 Gen 2 in Germany as it's written in the user manual and (more important) in the vehicle registration documents. As this are European documents, I think, yours should show your official correct wheels, too.
    The meaning of the numbers:
    16 -> 16 inch (=406,4 mm) is the diameter of the rim.
    195 -> 195 mm is the width of the tyre.
    55 -> 55% of the width is the radial height of the tyre.
    So the diameter D of the whole wheel is
    406 mm + 2 × (195 mm × 55%)
    = 621 mm
    The circumference is π × D = 1950 mm = 1,95 m.
    With 195/65R16 the circumference is 2,07 m. (That's +6,15%.)
    That means now speedometer is showing 100 km/h while you're driving 94 km/h for real (GPS?). That's similar to mine. (While I'm driving 100 km/h (GPS) the speedometer is showing 106 km/h.)
    If you'll change back to the smaller ones, which should be the right ones, you'll get even slower (about 88 km/h) while the speedometer still shows 100 km/h. That's a bit too much difference, I think.
    But better too less than too much at the speedometer
    While you're only on some German autobahn allowed to drive with unlimited speed, the reduced maximum speed of your Prius with the smaller wheels shouldn't be any problem for you in Greece, I think. But the smaller wheels results in higher torque, which results in higher acceleration (if they don't slip).
    It's your decision. Consider the speed thing but also your legal situation, which I don't know. (In Germany I'm only allowed to use the wheels, which Toyota let write into the registration documents.)
    SM-G950F ?
  3. lpf
    lpf Member
    113
    33
    Greece
    Good morning and thanks for the answer.
    what your speedometer shows for real 100 km/h?
    I'm thinking of fit 195/60 finally (3% difference from 195/55) or the original 195/55. There is not a legal problem here.
  4. MickyMatter
    260
    166
    Germany
    The speedometer is showing 106 km/h mostly (sometimes 107), while driving real 100 km/h (measured with the GPS of my cellphone)
    (At least in Germany it's a law that speedometers are allowed to differ up to 10% but never must not show too less.)
    SM-G950F ?
  5. lpf
    lpf Member
    113
    33
    Greece
    You have 195/55 and speedo shows 106 for 100km/h. I have 195/65 and the speedo shows 107-109 for real 100. Something is wrong here.
    Anyway I will try the correct size and see what happens...
  6. MickyMatter
    260
    166
    Germany
    To prove my dimensions, have a look at the pic. I'm using exactly this size (but with a lower speed index than V, as the car can't drive up to 240 km/h and tires with S, T or even H are usually cheaper).
    And I remember these speeds, when driving (all in km/h)
    Speedometer – GPS
    54 – 50
    86 – 80
    106 – 100
    138 – 130
    170 – 160
    The difference isn't an exactly linear factor, but that's my experience with my 2008 Gen2 Prius, bought from my dad, which was the first owner.
    Maybe your previous owner (the one of your car, of course! ) switched to some bigger tires and to prevent, that the speedometer shows less than the real speed, he eventually let the speedometer get newly calibrated? 20200429_163402.jpg
    SM-G950F ?
  7. lpf
    lpf Member
    113
    33
    Greece
    Thanks for all. I will come back early next month with new tyres and new observations. Stay healthy!
    MickyMatter likes this.
  8. MickyMatter
    260
    166
    Germany
    Thanks, you too!
    SM-G950F ?
