Rear Sway Bar
Discussion in 'Prime Accessories and Modifications' started by k3v11n, Mar 21, 2020.
  1. k3v11n
    k3v11n Junior Member
    Hawaii
    Anyone install a rear sway bar on their Prime? I've searched and doesn't seem to be any available. There are sway bars for other Prius models. Any idea if they will fit my 2017 Prime?
  2. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    It has a rear sway bar already. Are you looking for a larger one?
  3. mistermojorizin
    mistermojorizin Active Member
    310
    137
    usa
    2019 Prius Prime
    I'm also interested in this. Any larger aftermarket rear sway bar options?
  4. Ital
    Ital New Member
    CT
    2022 Prius Prime
    I did just find that Cusco now does carry the rear sway bar for the 2022 Prius prime. I am debating between this or the MEG stabilizer bars
    • Solid 24mm +50% (2WD)
    PRODUCT INFO
    MSRP
    $ 347.00
    Part No.
    1A1 311 B24
    That is from Cusco's website
  5. Sezy
    Sezy Active Member
    443
    231
    37
    Saint Charles, Missouri
    2020 Prius Prime
    Did a Cusco RSB and this extra brace. Has a nice stable but slide feel.
    20250206_170617.jpg 20250206_175815.jpg 20250206_175822.jpg 20250528_231915.jpg 20250529_012527.jpg 20250529_012542.jpg 20250529_012554.jpg
  6. richard203
    richard203 Member
    278
    61
    SF
  7. Sezy
    Sezy Active Member
    443
    231
    37
    2020 Prius Prime
    Like it's more planted on the ground when taking a corner. Almost like a rear wheel drive. In a good way.
  8. richard203
    richard203 Member
    278
    61
    SF
    do it make the steering wheel a little more firm? im trying to make my steering wheel a bit more firm and not so loose on the freeway.
  9. Sezy
    Sezy Active Member
    443
    231
    37
    2020 Prius Prime
    Not much for the front end. If you have nothing now, I'd start with the 3 MEG stabilizers bars for the chassis. Or look at a front strut bar.
