5th Generation Prius
Discussion in 'Gen 4 Prius Technical Discussion' started by padroo, Apr 19, 2019.
  1. Prodigyplace
    12,626
    11,808
    Central Virginia
    I have no issues with the spare tire in my 2017 Prius.
  2. Richard2005
    Richard2005 Member
    161
    69
    Australia
    In terms of where Toyota go with 5th Generation ... they either need to produce a much better PHEV (or possibly BEV) or alternately a much more efficient HEV. The later is a definite possibility because Toyota is very much focused on HEV for the Prius but more importantly for their entire line-up. So the 5th Gen Prius may be used to push the envelope further with another 15% improvement in HEV efficiency .. perhaps in part by taking thermal efficiency from the current 40% to 45%.
    The obvious technology for this is free valve or cam-less valves, as this gives much more freedom to improve efficiency, improve power (or reduce size) and also reduce weight. If Toyota were to initially release this in the Prius in low volumes (thanks to Gen 4 body style) then it could be migrated to other models down the track and I think that is where Toyota are really focused because hybrid has been very successful for them across their range and in many markets.
    Having said that I can find no market information to indicate Toyota are going down this path and they would have to be already very well progressed to make a 2022 release ... so perhaps this will take more time to develop.
  3. Mendel Leisk
    41,824
    I just wish they'd take a break from "pushing the envelope" for one gen, address the Homermobile this thing has become.
  4. ETC(SS)
    7,312
    But to be fair this is true of of more cars than just the Prius.
    Personally?
    I'm thinking that there will not BE a G5 - at least not a wireless one.
  5. Mendel Leisk
    41,824
  6. bisco
    52,284
    no rodent problems
    krmcg likes this.
  7. krmcg
    2,592
    2,392
    Whittier, CA
    short soy futures...
    Prodigyplace likes this.
  8. fuzzy1
    10,588
    As in non-plug-in?
  9. Mendel Leisk
    41,824
    Knowing @ETC(SS) I was thinking wire-guided weapon, lol.
    fuzzy1 likes this.
  10. ETC(SS)
    7,312
    Those are banned.
    Yes...I call the regular-old garden variety Priuses....the "wireless" kind.
    NOT "wire-free" @bisco.... Wire-LESS.
    That means that the soy-based wiring will still taste like Doritos to mieces.....
  11. Mendel Leisk
    41,824
    Or they apply that repellent sheathing to everything. Seems like realities of car ownership, like road salt and rats, don't much worry them?
  12. Prodigyplace
    12,626
    11,808
    Central Virginia
    I doubt you will find a Toyota with Honda Rodent Tape from the factory. They are the only current source of which I am aware.
    Mendel Leisk and krmcg like this.
  13. xerox6135
    xerox6135 Member
    170
    94
    michigan
    Thats was the reason I jumped ship . I had owed 3 prius . A gen 2 and 2 gen 3 went for 4th gen no spare tire was a del breaker for me
  14. xerox6135
    xerox6135 Member
    170
    94
    michigan
    Awd drive had no spare or a place to put one. Thats why I jumped ship to a ford fusion
  15. bisco
    52,284
    is the fusion all wheel drive?
  16. Mendel Leisk
    41,824
    The AWD Prius did kinda abysmal in one test video. And they lost me with that dog-in-manger rear inverter loc'n.
  17. Prodigyplace
    12,626
    11,808
    Central Virginia
    That is why I bought a 4th Gen with a spare. The Trim Three also had a spare. You were not trying hard enough.
  18. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Where else could the inverter go?
    krmcg likes this.
  19. Mendel Leisk
    41,824
    It seems like the levels with spare are eroding. Up here there's only 4 levels now, base and advanced, with/without AWD, and only base without AWD has spare.
    Well they could do some engineering, mod the body and suspension, make a proper space for it. My take: it's a minimum effort, minimum investment bolt-on, out with the spare, in with the inverter.
    And lacklustre test results of the AWD capability beg the question: is it mostly sales gimmick?
  20. Mendel Leisk
    41,824
    Merkey and royrose like this.
