Grocery store shelves are being emptied all over the country...
Discussion in 'Fred's House of Pancakes' started by Georgina Rudkus, Mar 14, 2020.
  1. Leadfoot J. McCoalroller
    6,690
    6,380
    Pennsylvania
    2018 Prius c
    I was going that far at first, but have since been talked down from that ledge. We're still insisting on delivery or curbside, haven't set foot in a store since early March.
    Still haven't been able to get TP, but I installed a bidet seat. Suddenly it feels like we're wasting space on rolls.
  2. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    Wife and I still go together, although there was word that they may limit to only one shopper. So we'll see.
  3. NewHybridOwner
    NewHybridOwner Active Member
    607
    278
    W. Michigan
    Someone said there was a run on laxatives now: people are running out of space to store the TP.
  4. ChapmanF
    14,980
    I have seen those, but struggled to imagine them completely effective. Or completely effective without pressure-washer levels of power, which call to mind ... other difficulties.
    In place of TP? Or just reducing use of TP? I guess I've never had Bidets 101.
  5. NewHybridOwner
    607
    278
    W. Michigan
    There was a headline suggesting that some bidets may permit fecal matter to enter the water supply.
  6. bisco
    48,862
  7. ChapmanF
    14,980
    That would seem offhand like a poorly-designed bidet.
  8. El Dobro
    El Dobro A Member
    6,972
    3,209
    Of all things, my store is out of wax beans and grape jelly. I didn't know these were being hoarded. :rolleyes:
  9. KennyGS
    1,243
    1,044
    Keystone State
    A few weeks ago, and without warning, my regular store moved the grape jelly next to the peanut butter, which was already in the bread isle. Sometimes I can't keep up.
  10. El Dobro
    El Dobro A Member
    6,972
    3,209
    This is a delivery order, they just don't have any brands left. They also notified me they're out of saltine crackers.
  11. bisco
    48,862
    I’n not sure if all shortages are caused by hoarding. There are also supply issues
  12. Tideland Prius
    16,017
    o_O :LOL:
    I see what you did there.
  13. Leadfoot J. McCoalroller
    6,690
    6,380
    Pennsylvania
    2018 Prius c
    Admittedly a leap of faith on my part. And if it were not for the fact that my better half had positive experience with one at her sister's house, I likely wouldn't have.
    General observations:
    Our house has ordinary water pressure, suburban shallow well pump setup. The device has an integrated water heater and came with a T-fitting so it shares the toilet's existing freshwater supply. Pressure has been appropriate to the task, at least for our diet. It's not going to take barnacles off a boat hull, but neither is "quilted northern." There are medical professionals ready for this. :eek:
    It has considerably reduced the need for paper. Paper is now for drying. The unit does have a convenient warm-air dryer but that one feature just isn't effective in a useful timeframe.
    Probably the biggest consideration I'd pass on to others is that the assembly does crowd an elongated bowl to the point where it feels like a classic round bowl after conversion.
    This has historically been an issue with the hose + pistol sprayer type, when a child or pet accidentally knocks the spraygun into the bowl, where there is potential for something to get past the one-way valve.
    The replacement seat type does not suffer this problem at all.
    jerrymildred likes this.
  14. NewHybridOwner
    607
    278
    W. Michigan
    We've had the occasional discussion of bidets, but in neither of the most-used bathrooms is there a power outlet adjacent to the toilet -- an intervening shower stall in one, and an intervening vanity top and cupboard in the other. Neither of us is crazy about having cold water directed at the pertinent areas.
  15. bisco
    48,862
    saw my first aldi tv ad tonight. seems like an odd time to start spending money on advertising
  16. Leadfoot J. McCoalroller
    6,690
    6,380
    Pennsylvania
    2018 Prius c
    Yeah that's a biggie. The overall power usage isn't high, but it's got quite the surge demand when the water heater kicks up. We were lucky to have an unencumbered 15A receptacle close enough.
  17. jerrymildred
    jerrymildred Senior Member
    11,490
    14,095
    Tampa, FL
    Ours is a much more basic design that has a bracket that mounts under the seat bolts. It's kind of clunky, but for me it saves on TP and inadvertent skid marks on the skivvies. :whistle: My wife, though, doesn't trust it.
    No heater on ours. Unless you run it a long time, the water is room temperature and that's fine with me. You do want to be careful in the summer, though. Our pipes go through the attic and, if it's been sitting up there very long, the cold is hotter than the hot. If you make the mistake of flushing and then using the bidet, you may scald your nether regions. :eek: I suppose that up north in the winter, it might be a different kind of shock.
    Prodigyplace likes this.
  18. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    You mean you are in the hot-seat? :rolleyes::oops:
    jerrymildred and Raytheeagle like this.
  19. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,474
    Bay Area, California
    2019 Prius Prime
    I like how this thread is based on food availability and we have now ended up at the other end of the spectrum :cool:.
    Now I know what it like to be a GI person (y).
    bisco and jerrymildred like this.
  20. Leadfoot J. McCoalroller
    6,690
    6,380
    Pennsylvania
    2018 Prius c
    My local grocery ran out of paper first and fastest. To the point where the entire paper goods aisle was stripped to the fixtures. Party napkins, paper plates, you name it. The entire thing was out to bare metal and stayed that way.
    Later there were some other shortages, but toilet tissue, paper towels and facial tissue have remained stubbornly unavailable while everything else recovered.
    We managed to get some of those heavy blue "shop" paper towels from the walmart. It's more expensive but it was the only thing available. We also switched to using more rags for household cleaning, cloth dinner napkins & doing more laundry.
    Mendel Leisk and Raytheeagle like this.
