Using the Prius Plug-in PRIMARILY as a hybrid, is it possible/mostly practical?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by masterjorn, May 7, 2020.
Tags:
  1. kenmce
    kenmce High Voltage Member
    1,509
    493
    NY
    Sure, no problem. Bear in mind that the pure electric range is modest. It already comes with a charger cord, you just have to find someplace to plug it in.
    If it has enough EV range for you it should work fine.
    No, its the opposite, a hybrid with a bigger battery, not an electric car with a backup ICE.
    jerrymildred and Tideland Prius like this.
