Fitting 18 inch wheels & lowering springs
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Lladnyk, Mar 13, 2020.
  1. pree_us
    pree_us Member
    64
    98
    Santa Clarita
    Did you add spacers? How thick . . . 5mm, 10mm?
  2. Itsmevince
    Itsmevince New Member
    SGV
    I put 20mm in the rear and I have 15mm in the front. It’s okay, but it sticks a little more than I like in the front. I have 10mm coming Saturday. I just dislike that I will have to extend the studs for 10mm. You can run 15mm in the back as well, but 20mm makes it flush with the wheel well.
    FYI, i didn’t try 5mm but I am 95% sure it will not clear the brake caliper.
  3. Dilpills
    Dilpills New Member
    OC
    2021 Prius
    Do you know if this is on springs or coils?
    iPhone ?
  4. outtabounds
    outtabounds Junior Member
    52
    Metairie, LA
    I ran across some aftermarket wheels on a mazda3 in the junkyard. They are 225x45x18 the tires are shot but the rims might look nice. I was wondering if they would work on my 2nd gen. If so would these look good? Looking on Google these have a 114.3mm bolt pattern and prius is 100 mm. Not sure what this means but prob the holes wont lineup with the studs. oh well was just a thought.
    #24 outtabounds, Nov 15, 2025
  5. outtabounds
    52
    Metairie, LA
    I tried these mazda rims on a prius b in the junkyard and they didnt fit.
