2014 Prius C one - battery dead & manual keys not working
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by fdeclerck, May 17, 2020.
  1. fdeclerck
    fdeclerck New Member
    evanston, il
    2014 Prius c
    Hi all,
    I am opening this as I could not find a good answer to help my case.
    Battery is dead and none of my 3 keys are able to open the door of my 2014 Prius C one.
    There is only 1 lock, at the driver door, no other. We do not have the smart keys.
    Note that a while ago, we tried the manual key and it didnt work already. I thought it was just the mechanical one that had the issue, but I never thought to try the wireless ones mechanically.
    Anyway, I tried:
    - the regular way on each of the 3 keys, both clockwise and ccw.
    - pulling the handle at multiple "heights", while turning the key (on either direction)
    - use some WD 40
    Turning the keys seem fine, I am able to turn, probably 30 to 40 degrees on each direction.
    This seem to have no effect on the lock .
    I will try AAA this PM.
    Any other tip would be nice.
    Thank you
    #1 fdeclerck, May 17, 2020
  2. Leadfoot J. McCoalroller
    8,118
    7,609
    Pennsylvania
    2018 Prius c
    Somebody's probably going to have to go in there with wedge & wire to manually unlock the door; regular locksmith service basically.
    I've heard of general reliability problems with the power lock actuators in these cars, but it was never clear to me whether that would affect mechanical unlocking via key.
    Let us know once you've got it straightened out.
    jerrymildred likes this.
  3. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    I’ve had both front door lock actuators replaced while on warranty. They just became very weak meaning that they couldn’t turn the lock inside the door. I never had a problem using the keyhole on the door nor manually using the lock lever on the inside handle. Your problem seems like if the linkage broke, that’s why turning the key on the door does nothing.
  4. bisco
    52,135
    make sure the wd40 gets inside the lock mechanism, and let it sit overnight.
    put a pair of pliers on the key for leverage, but don't break it. check the manual for correct opening direction, but wiggle it back and forth a little, applying more pressure in the correct direction.
  5. fdeclerck
    evanston, il
    2014 Prius c
    ok thank you, will try again today... DIdnt call AAA yesterday as it was downpouring.
    Ill try the keys again and will call if needed.
  6. fdeclerck
    evanston, il
    2014 Prius c
    WD 40 didnt work,
    AAA helped to open the door and recharge the battery.
  7. Leadfoot J. McCoalroller
    8,118
    7,609
    Pennsylvania
    2018 Prius c
    Don't forget to fix the lock so it's one less step next time!
    dig4dirt likes this.
  8. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    Curious, does the hatch open?
