Steering wheel returnability
Discussion in 'Gen 3 Prius Technical Discussion' started by tok16, May 18, 2020.
  1. tok16
    tok16 Junior Member
    Cambodia
    I just own pruis 2012 plugin, my steering doesn't return to the perfect center after turn. Any ideas on this?
  2. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    It's a wheel alignment problem. But you can check a few things first. The front tires should match, or at least be the exact same size, equally worn and inflated to the same pressure.
