Which Spark Plugs should I use?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius717, May 20, 2020.
  1. Prius717
    Prius717 Junior Member
    51
    Lancaster County PA
    My 2008 Prius is almost at 100K miles and I want to replace the Spark Plugs. i plan to stick with Denso / NGK. Rockauto has a few options for Iridium plugs, which are the best ones to get:
    DENSO 5303 Iridium Power: $4.72 each
    DENSO 4701 Iridium TT: $5.38 each
    DENSO 3324 Iridium Long Life: $5.71 each
    NGK 5464 Iridium IX: $5.23 each
    NGK 4996 Laser Iridium: $5.89 each
    Should I use anti-seize? Anyone know the torque specs for the spark plugs on a 2008 Prius?
    jzchen likes this.
  2. Mendel Leisk
    41,821
    From the Owner's Manuual, page 431:
    Torque spec is 13 foot/pounds from Repair Manual (attached*), I believe it's clean/dry threads, since the manual makes no mention of lubrication. If you use anti-seize, maybe reduce by 25% (recommendation I've read from Permatex).
    Still, I think the consensus from plug manufacturers is to not use anti-seize though. FWIW: last time I applied anti-seize very sparingly, then wiped it off the threads thoroughly with a shop towel, presumably leaving a slight amount, and reduced torque from spec by 2 pounds.
    * The Second Gen Repair Manual info is astoundingly better than Third Gen, btw. It manages to show (and it should not be that hard...), in one location: the socket size needed, and the torque spec. Third gen: socket size (14mm) is shown nowhere, and torque spec is off in another section, lumped in with the valve cover info.
    SFO and Prius717 like this.
  3. Prius717
    51
    Lancaster County PA
    Thanks for information! Much appreciated!
  4. Mendel Leisk
    41,821
    Check with dealership parts department too, sometimes Toyota's revised the heat range.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    This one is the SK16R11. Do not order them from Amazon. These are very popular for Chinese counterfeits. Purchase them from a reputable dealer or you'll end up with misfire issues 30k miles down the road instead of 100k+ miles.
