2007 prius wont start after hybrid battery repair
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by waveposer, May 19, 2020.
  1. waveposer
    waveposer New Member
    MI
    It all started with the red triangle and purple battery lights when first starting Prius. I read many post and took out hybrid battery. I found and replaced 1 battery that was reading lower voltage ( 6.6) when all the rest where 7.8. I completed load test on all the batteries with a headlight bulb. Balanced battery overnight, all cells reading 7.65 or 7.66. Installed hybrid back and now I have 214 volts at the battery but car will not start, all lights on including red triangle on. Battery symbol on displays showed around 4 blue bars. Car will shift into N if that means anything. I took side cover off hybrid battery and turned car on. I am not getting any voltage past where the batteries connect to Relays ?. I don't have schematic off any kind. I am very comfortable TS electronic/electrical issue. I have not pulled any codes yet.
  2. JC91006
    JC91006 Senior Member
    16,772
    8,567
    You probably forgot to lock the orange interlock device on your battery
    Raytheeagle and SFO like this.
  3. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Welcome to PriusChat!!
    Can you post some pictures of the HV battery, including the relay/ecu area.
    Raytheeagle likes this.
  4. waveposer
    MI
    Orange jumper in
  5. waveposer
    MI
    here is picture
  6. JC91006
    16,772
    8,567
    Looks like you haven't bolted the battery down to the car chassis. You need at least a couple bolts in
  7. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Only one exposed hole there, and I was still playing where's waldo :rolleyes:
  8. Phillip Griffith
    Phillip Griffith Junior Member
    43
    Columbia Alabama USA
    Having seen your post ;I dont see a final answer. Any update to your problem?
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    It will throw a code if that grounding bracket is not installed across the 2 leads where they enter the battery box but maybe he took that apart just to measure dc.
    If it was bolted all up and still not starting it may have a corroded battery ecu plug or a broken or rotted temp sensor.
    Pulling the codes it’s throwing will tell u why it’s unhappy.
    Phillip Griffith likes this.
  10. Mycaleum
    Mycaleum New Member
    Utah
    Happened to me. Push it in and then slide it down. Then cycle the ignition a few attempts and it'll sort it out.
  11. Phillip Griffith
    43
    Previous owner cut the grounding strap , I will make certain that it is reconnected firmly my next attempt at starting the car. My discussion is in Prius Gen 2 "What's wrong with this procedure?"
    #11 Phillip Griffith, Nov 28, 2020
    edthefox5 likes this.
  12. rodri9o
    rodri9o Junior Member
    56
    22
    NY
    ....who does that....
