Do Toyota Dealers 'RECONDITION' the Hybrid battery?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Oct 6, 2019.
  1. ski.dive
    ski.dive Active Member
    967
    245
    Hutchinson Island,FL. Mt. Snow,VT
    How much do they charge?
    52,421
    no, its free
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    What ??
    I think the real answer is: NO they don't and won't........with a few possible obscure exceptions.
  4. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Raytheeagle and Elektroingenieur like this.
  5. Elektroingenieur
    2,515
    3,287
    Three Touring
    There are no procedures in the Repair Manual (more info), or as far as I know, in other Toyota publications, for HV battery reconditioning, only for removal, disassembly, reassembly, and installation.
    There is a procedure for charging the HV battery with an external charger, but this is used only if the HV battery is so discharged that the engine cannot start. For North America, the details are in Toyota bulletin T-SB-0119-15, “High Voltage (HV) Battery Rescue Charge (HEV Workstation / GRX-5100).” As Toyota writes in 2016 Toyota New Technology Update: Course TIN516A Handbook, “A rescue charge does not ’refurbish’ the HV Battery or repair faulty cells within the HV battery pack.”
    @SFO's kind suggestion to ask the dealer is a good one, however. Dealers are independent businesses, and I don’t know why they wouldn’t be allowed to offer their own HV battery reconditioning service, if they choose, just as they can offer other services not recommended by the manufacturer.
    Graeme1949 and SFO like this.
  6. PriusCamper
    PriusCamper Senior Member
    13,105
    5,312
    Pacific Northwest, USA
    Toyota addressed the known problem of nickel-based batteries needing to be reconditioned by allowing the battery pack to continue to operate the car when the pack is so in need of reconditioning it's only at 50% of original capacity. Reconditioning or "cycling" the battery pack several times can restore the pack to 96% of original capacity. Toyota had to decide between investing in a battery maintenance service, or even building a system into the vehicle, vs. investing in a battery pack that would last just long enough for the owner to spend thousands replacing the battery pack or the car. While profitable, their decision is also wasteful and irresponsible in a world with finite natural resources. So companies like hybrid automotive and other built aftermarket systems for battery reconditioning. Learn more here: FAQ
  7. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    That’s why it’s free. Because they won’t do it. Bisco logic, not mine. :whistle:
    donbright and bisco like this.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    The OP joined Prius Chat in 2008. That's 11 years ago.
    I joined in 2009.
    Now speaking only for myself.
    I have never read a single thread that talked about a Prius Owner taking their Prius to a Toyota Dealership for Hybrid Battery reconditioning.
    So why the question? I think it's answered by empirical default over the course of a decade.
    Mendel Leisk, Skibob and bisco like this.
  9. bisco
    52,421
    maybe a rhetorical question (n)
  10. bisco
    52,421
    dealers will 'RECONDITION' your bank account though, if you let them ;)
    Mendel Leisk, Skibob and donbright like this.
  11. PriusCamper
    13,105
    5,312
    True on all points... Yet you've clearly underestimated the ridiculous nature of social media-based DIY forums...
    SFO and bisco like this.
  12. Gary Kiviniemi
    60
    91
    Manchester TN
    Things change I suppose.
    The Toyota dealership in Murfreesboro TN offers a reman with 6 month warranty for $1700 incl tax. Out the door of parts dept. (Not including install).
  13. Skibob
    2,912
    1,505
    Northern California
    I don't see that as a very good deal. You can get a brand new Toyota factory battery for 1655.36 + tax. currently. Should last at least 10 years.
    Battery - 2004-2009 Toyota Prius (G9510-47031) | Tracy Toyota Parts
  14. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Do they define "reman?" If it has all new cells and they cleaned or replaced all the connectors and harnesses that needed it, that would be about what would happen if you bought a new battery. If it's mix & match and not replacing all the cells, then that would be like the refurbs that only last a few months.
    SFO and Raytheeagle like this.
