New radiator or unclog a partially clogged one?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ttou68, May 22, 2020.
  1. ttou68
    ttou68 Active Member
    340
    198
    Background..
    2010 Prius currently with 209K miles, bought it with blown head gasket and seller claim no gasket sealer was using but found clear gelatin with some kind of minerals mixed inside when performed coolant drain...
    I've been keeping an eye on engine operating temperature, and found it flow between 186°~199° after water pump replacement and radiator hose from thermostat to radiator feels warm after about an hour of interstate driving while other hoses and coolant reservoir is way warmer...
    Last night I pulled off the thermostat and test it to find it's working properly, and noticed radiator took a while to drain...
    Is it worth it trying to unclog this thing and say I win or just order a new radiator and call it a day?
    I really don't want flush the engine in the process, and have to deal with water inside motor and 50/50 coolant.. I've checked with dealership, they don't carry concentrated coolant.. and I really didn't want to take the radiator out of the vehicle to clean it..
    Call me lazy.. haha..
    If anyone has experience and success in unclog a radiator, please advise..
    Thank you in advance!
  2. ASRDogman
    ASRDogman Senior Member
    5,905
    3,167
    You could take it to a radiator shop and ask them to flush it.
    They can put higher pressure and volume through it than you can.
    And usually they will warranty it. Unless it's in bad shape, they will tell you.
    Before you pull it, you can disconnect the hoses try flushing with a hose. It should flow
    out almost as fast as you put it in. Let it drain, then block the lower hose fitting,
    and fill it with white vinegar and let it sit for an hour or so... Some people have had
    good luck doing that. You should also do that to the heater core.
    ttou68 likes this.
  3. Mendel Leisk
    38,247
    Someone here emailed one of the stop leak manufacturers, and they recommended to fill the system with a 50/50 mix of white vinegar and distilled water. It worked a charm for them: dissolved the clumps. Now whether that would work with your stuff you would need to test. If you can get some of the goop out, test by dropping it into such a mixture, see how it reacts.
    Assuming it does work, dissolves the goop: drain both the radiator and the block*, and maybe disconnect the lowest hose on the exhaust heat recirculation system. Try to get the system as emptied as possible. Then fill with the mix, leaving the engine coolant bleed bolt open to vent as you pour it in (it's a black/white contraption on a hose directly above EGR cooler. You might want to remove wipers and cowl (if you haven't already), for access to the bleed bolt and the block drain.
    Try to catch all the drain, and measure how much you get. It comes in handy, to calculate coolant/water percent later.
    Run the engine in Maintenance Mode, squeeze hoses and top up as needed. Be sure to have your cabin heat set to high. Keep going till the radiator fan cycles on/off.
    Then let it cool down, drain again, as completely as possible. Then it's a bit of a quandary: you have a relatively cleaned out system, but a "certain" amount of water/vinegar residue still in there. If you just refill with 50/50 Super Long Life Coolant, it's going to be somewhat diluted, and contaminated with vinegar.
    Maybe do one more fill and drain with straight distilled water. And again, when draining carefully measure what comes out, compare with the system capacity spec (7.3 liters, 7.7 US quarts, see attached also). Compare the drained amount with system capacity, to determine how much water is still trapped in the system. Then refill with full strength Super Long Life Coolant, not the premix (if you can find it), or Long Life Coolant (which comes full strength I believe), diluted with distilled water just enough to achieve 50/50 mix. Or maybe 55/45 (coolant/water) mix. The latter is the spec for Canada, might be good to err slightly on the "strong" side.
    Keep in mind the change interval for Long Life Coolant is shorter, maybe half? So maybe just run that for a couple of years, then drain and fill one more time with Super Long Life Coolant, the premix.
    * The engine block coolant drain is a small bolt with a spigot directly below it. It's up fairly high on the block, on the rear side, towards the passenger end. It's in the vicinity of the oil temp sensor and timing chain tensioner, just a little over. You can just see and reach it from below, with the car raised and engine under panel under. Push a 5/16" hose onto the spigot, and loosen the bolt to start the drain.
    More than once it's been said here that hardly anything comes out when you drain the engine block point, but I've yet to do it, would want to see for myself.
    #3 Mendel Leisk, May 22, 2020
    Raytheeagle, pjksr02 and ttou68 like this.
  4. ttou68
    340
    198
    Heater core is actually fine, I've checked it while doing the head gasket.
    I've bought a gallon of vinegar and 5 gallons of distilled water, and was preparing to flush it the old fashioned way. Then I decided that the engine itself is fine and I couldn't find concentrated coolant at dealership..
    This is the closest I've found, and think it might work...
    2012 Prius v wagon 3 likes this.
  5. ASRDogman
    5,905
    3,167
    Glad the heater core is clear. And hopefully, the rest of the system. Maybe a new thermostat?
    Since you have it out anyway, cheap enough to replace.
    I personally wouldn't use anything but what Toyota calls for. Different coolant don't always mix well.
    I would flush it as Mendel says above, and then maybe twice with just water. And leave the thermostat out
    so the water can circulate throughout.
    Then install the thermostat and fill with the coolant Toyota calls for, the 50-50 mix.
  6. pjksr02
    pjksr02 Active Member
    532
    225
    Connecticut
  7. Mendel Leisk
    38,247
    Toyota Long Life Coolant (without the "Super") is approved I think (need to check), just shorter change interval. Again, (need to check) but believe it's full strength.
    pjksr02 likes this.
  8. Mendel Leisk
    38,247
  9. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    With that many miles and head gasket info, I’d go with ride til it dies and keep building the emergency saving to save up for a non hybrid vehicle with medium miles.
  10. ASRDogman
    5,905
    3,167
    The only way to get ALL the water out is to rebuild everything.
    ORrrrrrrr, hook an air hose up to the radiator and blow air through the system for a few days...
    You don't need to get ALL the coolant/water out. He just wants to saw the radiator if possible.
    Flush it with the vinegar, then 2 rinses with just water. That will be good enough. 3 or 4 if that will
    make you feel better. The little bit of vinegar left won't do anything.
    ttou68 likes this.
  11. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    Easier method, put the entire thing in a ziplock bag with rice in it.
    pjksr02 and ASRDogman like this.
  12. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    276
    Redwood City, California
    Have you ever seen what happens when you put tap water into an Aluminum-block car engine. Have you seen one literally melt and crumble away before your eyes?
    Me either, but the way you see some internet writers follow the letter of the specs on that, you might wonder. :ROFLMAO:
    So I would not worry so much about using distilled water during the flushing phase. And once it is pretty much clean of any antifreeze, you might try repeated flushes with hose water, monitoring what comes out.
    After doing a full final drain before the actual re-filling, I'd assume some small amount of water (hoped to be pure enough) remains, so adding 50/50 may not be the best thing. So aiming for 50/50, I prefer to put in 100% equal to half the specified cooling system capacity, and fill the rest with distilled water.
    I still have the original coolant in my Prius, and will probably go to the minor effort of getting the specified Toyota coolant when flushing both systems as needed. But I saw your pic of the Peak. If it is significantly more convenient for you to get that now, I'd use it. I use that in many of my cars, and it is convenient to use the same coolant (or ATF, engine oil, etc.) when possible, for different cars just so you don't have so many different half-full bottles on the shelf.
    The true main thing you need to be concerned with when changing coolant is for compatibility between the new and old fluid - you do not want any reaction between the two. But most ethylene glycol coolants (like that Peak and like the Toyota stuff) are probably compatible and not likely to gel into a solid, or even catch on fire. BTW, all the different colors are artificially added. So it's not like the green stuff and the pink stuff come from different planets.
    I believe the main reason there are so many different specs out there (esp. from European cars) is that different countries will have their own special environmental regulations, and some, like Germany, may try to continually out-do the previous administration with something even "greener" to appease the tree huggers (can I say that here? :censored:). At the end of the day, none of these coolant options are designed to melt aluminum on contact. Virtually anything will work.
    OK internet. Fire away.:LOL:
    And separately from the coolant issue, a radiator should be pretty cheap, and given the miles it has already given you, I'd probably just replace it if it were my car.
    ttou68, Ed Beaty and Mendel Leisk like this.
  13. ASRDogman
    5,905
    3,167
    ....But most ethylene glycol coolants (like that Peak and like the Toyota stuff) are probably compatible .....
    Probably.....
  14. Mendel Leisk
    38,247
    That's hands-down bullet-proof. (y)
  15. ttou68
    340
    198
    Thank you
    Yes, that's why I made a post here to see if anyone has innovate away to do this..
  16. ttou68
    340
    198
    Also, I don't planning on keeping this car long. It's a fix upper I'll be using it for work travel....
    I figured it out long time ago that using a cheap fix upper like a Prius to rack up the miles ($0.58 per mile), and saving on file ((approximately $20 each way) then sell it at the end of my work travel... Way cheaper than putting miles on my personal vehicle. This year will be 12 weeks of driving 700~800 miles per week back and forth for work..
    I usually don't have many issues fixing up a vehicle, but this time I decided to take on one with blown head gasket (my first), plus seller had used gasket sealer and didn't honestly answer my questions before purchasing..
    With that being said, I personally own a few hybrids currently. Lexus, Toyota, and I've gained a ton of experience on maintaining vehicles for myself and family with every "project" work vehicle I purchased and fixed up!
    #16 ttou68, May 23, 2020
  17. Mendel Leisk
    38,247
    One head scratcher: the Owner's Manual (and Repair Manual) say "system capacity" is 7.3 liters (7.7 US qts). I think that's the starting-from-dry, how much it'll take capacity. But not 100% sure. Pretty sure though.
    If you're dealing in US qts, and have done a thorough water flush, this is what I would do, following @2012 Prius v wagon 3 's lead:
    1. Drain the sytem.
    2. With air bleed bolt open, Add 4 quarts* of Toyota Long Life Coolant (the 100% stuff, not the "Super" pre-mix).
    3. Continue filling with distilled water, burping the coolant hoses, till you've got the coolant level stable at the top mark in reservoir. At whatever point in the process coolant starts coming out of the bleed bolt, quickly shut it.
    4. Follow @NutzAboutBolts coolant change video from there on, topping up as needed with distilled water (not pre-mix).
    The one downside: the Toyota Long Life Coolant is rated (IIRC) to be good for only half as long. I would just use it for maybe 2 years, then do another exchange with Super Long Life Coolant (the pre-mix). That is if you've still got the car, lol.
    * System capacity is 7.7 US qts. multiply that by 0.5, is roughly 3.85 qts. Mutiply by 0.55, is 4.23 qts. The latter is the Canadian SLLC pre-mix percent, so I'd think just using a full 4 quart bottle is both convenient and "in the ballpark".
  18. ttou68
    340
    198
    Update....
    Went to auto parts store today and had a conversation about my radiator issue, and got some interesting and sound information..
    I've always thought the clear gelatin objects came out of engine coolant system, was the result of head gasket sealer.
    Today, I was told otherwise, turned out that organic acid in Toyota coolant will gel with other brand coolants when mixed together.
    The seller of the fix upper Prius, had been using green coolant made for " all vehicles " instead of Toyota super long life, because Toyota coolant is too expensive to blew coolant out the tailpipes! LOL
    Based on that information, I was suggested to use BlueDevile radiator flush and oil degreaser to clean out the radiator.
    I was also told to use 50/50 coolant like Toyota super long life, and not to worrying too much about the concentration level. Because water in the system will evaporate and summer is near, so just keep an eye on it, top it off when needed..
    So, I plan on flush the system with BlueDevile and using water and vinegar mix right after then distilled water to clear out the system.
    Fingers crossed!
  19. GabrielD
    GabrielD Member
    179
    71
    Romania
    2014 Prius+ MPV
    With all the flush and vinegar or acid flush you cannot do it as a new one.
    I think buying a new radiator is something you should consider...
    You can find from 100 usd to 400 usd on autozone
  20. ASRDogman
    5,905
    3,167
    This is why it's best to know ALL the information before giving a diagnoses...
    Which is hard to do here.
    I understand why the previous own did what they did. But they didn't understand
    the damage they were doing.
    I hope this works for you!
    ttou68 likes this.
