EV range
Discussion in 'Prime Fuel Economy & EV Range' started by titefd, May 20, 2020.
  1. titefd
    titefd Junior Member
    Greetings. Has anyone verified a decrease in EV range on higher mileage prime models ? Or even the gen 3 plug in ? If so by how much has that EV range come down and at what mileage was on the vehicle ?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,041
    7,580
    near Brisbane, Australia
    Do you mean seasonal range - or over time?
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    What's higher mileage?
    And under what conditions (highway driving, city driving)?
    alanclarkeau likes this.
  4. Salamander_King
    Salamander_King Senior Member
    10,964
    8,840
    New England
    I think the battery degradation is more of function of age than the mileage. The oldest PRIME on the road today is ~4 years old. There are a few owners who reported decreased EV ranges within that period, but we don't know how universal that is. For my 2017 PRIME, overall EV range actually increased after first two year, primarily due to the change in the way I drove the car. Seasonally, the EV range diminished in winter time 30-50% compared to summer time for me.
    benagi and alanclarkeau like this.
  5. bisco
    48,985
    it's all over the place. mine degraded about 15% in the first couple years, and has stabilized around that number ever since. 70,000 miles, 50,00 of which are pure ev
  6. Tideland Prius
    16,072
    You have a different car. There's a good possibility the PiP's chemistry is different from the Prime's.
    bisco and alanclarkeau like this.
  7. bisco
    48,985
    agreed. but the o/p asked for both, and i think if you look over the prime threads, you'll find reports of degradation all over the place, just like the pip. there is no standard expectation.
    Tideland Prius likes this.
  8. benagi
    benagi Active Member
    525
    280
    Utah
    My 2017 prime is almost 3 years old. I see no degradation yet. But then again, I only have 17,000 miles on it and 99% of my mileage is EV only.
  9. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    My 2013 PiP had 53k miles on it when I bought it. 2-1/4 years later it had about 86k on it and still had as close to the same range as I can estimate given variables in weather and other driving conditions.
    I've had my 2017 Prime for 14 months. It's gone from 23,000 to 43,000 miles. Range is still over 30 miles this time of year. If I just drove local surface streets, it would probably be close to 40.
    Comparing ranges is really meaningless because it's so greatly affected by speed, driving style, traffic conditions, terrain, temperature and so on. I could easily convert my range down to the low 20's just by going north in the winter or simply by stupid driving right here in FL. For example, yesterday, I had to drive freeways mostly. I got 4.5 m/Kwh. Today, I drove slower and got 5.4 m/kWh. The only independent comparisons would be how many kWh it takes to charge the battery but even that can vary with how deeply into the HV part of the battery it's gone when you shut it off to charge it.
  10. Tideland Prius
    16,072
    The other day by following the Eco Accelerator Guidance, I got 6.94m/kWh! (New personal record) It was a 25 mile round trip.
    (9.0kWh/100km or 90Wh/km over 40km)
  11. bisco
    48,985
    i'm up to 13.2 miles estimated range with the improving weather :)
    jerrymildred likes this.
  12. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
    Mine really didn't degrade at all after 4.5 years and 81,000 miles as of this video below. In fact, that particular daily morning commute delivered more EV range than you'd anticipate from the system new.
    The point being, set realistic expectations. Some owners don't, then get baffled later upon making an observation they have a difficult time verifying.
    I have a set of videos 2 years apart with my Prime... same route & conditions... no degradation with it either, as the digital capture helps to confirm. Will it loss some range later? Most likely, but the EV miles during the summer are still greater than the rated distance anyway (now at 3.1 years). So, I call it good.
    #12 john1701a, May 22, 2020
    jerrymildred and benagi like this.
  13. bisco
    48,985
    i know, nothing bad ever happens to your toyota's :)
    Raytheeagle and Tideland Prius like this.
  14. Raytheeagle
    11,251
    15,476
    2019 Prius Prime
    Because he knows his audience:p.
    Tideland Prius and bisco like this.
  15. Randi
    Randi Junior Member
    71
    Prescott Valley, AZ USA
    2020 Prius Prime
    I’m getting 30 miles on EV. :)
  16. bisco
    48,985
    i'm jealous!(y)
    Raytheeagle and Randi like this.
  17. jerrymildred
    11,491
    14,100
    Tampa, FL
    I drove out all my EV yesterday. It was 21 miles each way. Mostly 50 mph. Stayed in EV till it ran out at 32.4 miles. Engine came on and I reset trip A. It read 65.8 mpg when I got home.
    Edit to add: It was around 90F, so I was running the air conditioner all the time.
    Randi and Tideland Prius like this.
  18. Randi
    Randi Junior Member
    71
    2020 Prius Prime
    Wow!
  19. Raytheeagle
    11,251
    15,476
    2019 Prius Prime
    Trade your blue PIP in for a Blue Magnetism Prime :):
    Jealously into action(y).
    #19 Raytheeagle, May 27, 2020
  20. benagi
    525
    280
    Utah
    I started out around 29 miles of EV the beginning of spring In northern Utah. As of today my GOM is up to 34.2. My commute is 20 miles round-trip. 80% freeway at 70 miles an hour, 20% in town at 30 miles an hour.
    Still loving my 2017 prime advanced.
    Randi and john1701a like this.
