Prius Battery Replacement (GenII) Like you've never seen - NEW Cylindrical Cells
Discussion in 'Gen 2 Prius Main Forum' started by 2k1Toaster, Jul 17, 2017.
  1. George W
    George W Active Member
    909
    510
    San Antonio
    There should be ductwork that connects the HV battery to an exhaust Port that is located above and behind your 12-volt battery The HV battery is composed oh 28 NiMH modules , connected in series like Christmas tree lights. When you remove the orange safety plug, you are opening that series circuit, removing the high voltage.
  2. royrose
    royrose Senior Member
    1,389
    948
    Foot of Pikes Peak
    The high voltage battery, also known as the traction battery that powers the hybrid system, is an NIMH battery that does not have a battery acid hose. As stated by George W above, it is made up of 28 modules (that are sealed). It is not a lithium battery. Only very experienced owners install a high voltage battery on their own.
  3. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    No and you cannot put a Lithium Ion battery into a Prius charging system designed for Nickel Metal Hydride.
  4. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    See page 12 of the 2007 brochure. (Sealed Nickel-Metal Hydride (Ni-MH)
    Prodigyplace likes this.
  5. hill
    8,070
    what type lithium ion are you looking for ... there are several on the market ;
    StackPath
    Not all are created equal
    #605 hill, May 23, 2020
  6. Prodigyplace
    11,696
    11,317
    Central Virginia
    Many but not all Gen 4 Prii have Lithium Ion battery packs.
    jerrymildred likes this.
  7. roccostud
    roccostud Junior Member
    Seattle
    they are
    NiMH like the original and they are not vented. the vent hose is not needed on the cylindrical cells.
  8. Prodigyplace
    11,696
    11,317
    Central Virginia
    WRONG they are NOT Lithium Ion.
  9. dolj
    dolj Senior Member
    7,505
    3,772
    Wellington, New Zealand
    I think he meant:
    They are NiMH like the original and they are not vented. The vent hose is not needed on the cylindrical cells.
  10. Berch1943
    Berch1943 Member
    146
    Arizona
  11. royrose
    1,389
    948
    Foot of Pikes Peak
    Please explain more fully what you are doing. Are you replacing your hybrid high voltage battery with cells from new prius batteries? If so, where are you in the process?
  12. Berch1943
    Berch1943 Member
    146
    Arizona
    Yes I’m replacing. I preordered mine. Already took the old battery out. So I wanna know if I understand correctly before I install.
  13. George W
    909
    510
    San Antonio
    Some day you may want to put OEM back in the car. Keep the old vent hose, you never know when spare parts will come in handy for older Prius.
    jerrymildred and Mendel Leisk like this.
  14. roccostud
    Seattle
    didn't say they were .
  15. Prodigyplace
    11,696
    11,317
    Central Virginia
  16. jerrymildred
    11,491
    14,100
    Tampa, FL
  17. Berch1943
    Berch1943 Member
    146
    Arizona
    Is there a pdf copy of the instruction manual?
  18. Prodigyplace
    11,696
    11,317
    Central Virginia
    I looked on the website where you buy the kit and the instructions on that page looked pretty straightforward.
  19. George W
    909
    510
    San Antonio
    Ask 2K1Toaster, the man you preordered from. He'll be happy to email you a pdf of the procedure. Also, check out youtube videos for clues to the details the Instructions skipped over. I don't know how often this manual is updated, but I had to re-read certain sections several times to understand where steps are slightly out of sequential order.
    Also, if you see youtube videos of guys who claim they can do it in an hour or less, they are skipping steps they've learned through rote, but a novice should see. If you see that one video of a guy who does it in 28 minutes, he's injured his spine doing this work, so you won't learn anything but how to ruin your back.
    James1964 and Prodigyplace like this.
  20. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    You don't need those vent hoses because cylindrical batteries vent through the terminals on each cell if overcharged. This is something that almost never happens in the Prius. And the prismatics need it because when it does happen in the plastic casing, it has to vent. But with cylindrical modules, they don't need to vent until a much higher pressure because the metal cylindrical shape can withstand MUCH higher pressures. If they ever vent, something disastrous has happened and the vent hose on the original pack wouldn't have saved the situation anyways.
