A/C needs to full recir
Discussion in 'Gen 3 Prius Accessories and Modifications' started by douglasjre, May 22, 2020.
  1. douglasjre
    douglasjre Senior Member
    1,774
    617
    Orlando, FL
    Ionizer mode is temporary. How do i force it to stay 100% recirc
  2. Mendel Leisk
    38,260
    Maybe that's not safe? Carbon dioxide build up and so on?
  3. StarCaller
    StarCaller Senior Member
    1,240
    692
    Cedar Crest, NM, USA
    if you choose recirc by hand it wii stay (until you shut the car off) /
    Data Daedalus likes this.
  4. ASRDogman
    ASRDogman Senior Member
    5,908
    3,167
    If you put the ac on auto, it goes to recirculate. I always turn it off if the car has been
    parked in the sun and is hot inside. 95 degree air cools a lot faster and easier than 125 degree does.
    And open the windows and put the fan on high. After a minute or so I just press the auto button again.
    Just be careful, if you leave the fan on low speed, and have a low temp setting, you could freeze up
    the evaporator. You'll by it getting hotter, and no or little air coming out of the vents.
    Turn the compressor off, turn off recirculate, and put the fan on high speed. You'll have air coming out
    in less than a minute. Give it another minute to melt the ice.
    jerrymildred likes this.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,783
    2017 Prius c
    What exactly is "ionizer mode" ?
    There is no true 100% recirc for safety reasons.
  6. bisco
    48,999
    just keep pushing the ionizer button. otherwise, recirc still lets in some fresh air
  7. ASRDogman
    5,908
    3,167
    It's really only about 90% recirculate. 100% outside air.
    The ionizer is supposed to clean the air. But it only take the outside air.
    Seems it would be smarter and better to clean the recirculating air.
    Maybe it just cleans the evaporator.
  8. Data Daedalus
    Data Daedalus Senior Member
    1,022
    1,182
    Wembley, London
    There’s an ionizer button?!! Where?!!....
    (No, I’m not joking...).
    iPhone 6s +
  9. Data Daedalus
    1,022
    1,182
    Wembley, London
    Oh wait.....you’re talking about a 3rd Gen Prius! My bad....(do people still say that?).
    iPhone 6s +
  10. bisco
    48,999
    all the time :p
  11. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    Easy fix, keep your pandemic mask on while driving.
    Data Daedalus, RMB and Mendel Leisk like this.
  12. douglasjre
    1,774
    617
    Orlando, FL
    What's the ill effect if we leave the ionizer on? I've heard specualtion...but it's not an ozonator after all. That is bad for sure even for short periods. Any help understanding is appreciated. I live in FL where there is high high high humidity. Recirc lets me dry it down. Mucho essential. I will say the car does auto set recic/fresh well for most people. I just demand low humidity. If it's over 45% I'm quite uncomfy. I'm shooting for 30-40%. I'm like a walking hygrometer.... Got my house dried down to that too :)
  13. Greenteapri
    Greenteapri Active Member
    330
    387
    Cypress
    Do you think this is true in Texas heat when it's one hundred degrees?
  14. ASRDogman
    5,908
    3,167
    I was stationed in Texas. It get HOT there! It's 90-95 degrees outside. But inside a closed
    up car, it will get 125-130 degrees. Which do you think will be easier to cool? And which is faster?
    Once it starts cooling, you can turn on the recirculate.
    If you have the temperature to the coldest setting, and the fan on the lowest speed, the evaporator
    will freeze up.
  15. sam spade 2
    7,035
    2,783
    2017 Prius c
    You can demand all you want, in Florida in the summer time it just AIN'T gonna happen.
    Start the car 10 minutes before you get into it with the AC on. That's about the best you can do.
    And.....what is an "ionizer" ??
